pukajoe, you left out a few steps.
Remove the center climate control knob by just pulling it out. There will be a screw there. From the back of the plastic trim around the gear lever, pull upwards until you can take it off (it's the piece the 12V is connected to). There will be another two screws on the bottom. Take the two screws out and then tug firmly on the whole plastic piece of the console. Manuever it around and it should pop right out. Then there will be total 4 bolts you have to remove to take off the stock headunit. I forget, but they are either all on the bottom or two on the bottom and two on the top. Pull the headunit out, do what ya gotta do and reverse the process.
