Grounding trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2005, 07:18 PM   #1 (permalink)
1996 Corolla DX
View KidComa's Photo Gallery
Canada Grounding trouble
Hello, I'm trying to install an amp in my trunk (a 96 Corolla). I'm having a hard time finding a place to attach the ground wire. It seems as though I get conductivity with a couple of screws by the taillights, but when I actually screw them in with the wire, it doesn't seem to work. (plus these screws are far from the amp.) Any suggestions as to where the best place to ground is???
Chris
KidComa is offline   Reply With Quote
Old 03-16-2005, 09:13 PM   #2 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Try going under the carpet and just drill a hole somewhere safe, scrape off all the paint and screw it down or you could use a grounding terminal block like i did and then screw that down.
http://www.xclusive.bz
Old 03-16-2005, 09:33 PM   #3 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
you could use one of the rear seat belt bolts.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 03-17-2005, 09:05 AM   #4 (permalink)
View Crowleys Camry's Photo Gallery
Yes make a hole sand down to bare metel and bolt it on with nut and bolt make the hole same size as the negative connector from amp you can make a hole any where just make sure you can hide it . This would be the best way to make sure you have good ground.
Crowleys Camry
Crowleys Camry is offline   Reply With Quote
