Originally Posted by cinnabar
Would I do anything if I tried the orange/white on the OEM green wire?
Don't do that.
Orange/white = dimmer
OEM green wire = illumination (parking light).
Illimination and dimmer is 2 different things. If your deck had a orange wire (not orange/white), you could tie that to the OEM green wire.
The deck should function properly regardless if the orange or orange/white wire where hooked up or not.
The audio shouldn't be cutting out whenever the parking lights or head lights are on. That tells me your deck is wired wrong or something is shorting out.
Recheck your wiring.
