Electronic Trunk Pop - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2005, 10:19 PM   #1 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
4th Generation Electronic Trunk Pop
Ok
So my next sudo project is to install a trunk pop in preperation for an alarm, my audio shop said it would be 75 bux, if i can do it for half that ill go through with it. BTW I have a V6 Gen 4 Camry. Ive done some reaserch this thread seemed somewhat helpful:
electric trunk release/pop/popper installation
i think the only difference is that I want to mount the acutator under or near the drivers seat, so it will be easy to run a button for the trunk near the mirror controllers. Can Anyone reccommend a general guide on how to go about doing this. Or how about a kit. Ive seen these on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33656
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Thanks as always for skoolin the unlearned
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 03-23-2005, 12:14 AM   #2 (permalink)
How Ya Like Me Now?
These seem to have good reputations around the net
http://www.duettomotors.com/general/...%20Trunk%20Kit
http://www.caraudio-caralarms.com/522T.html
98 V6 XLE
Old 03-23-2005, 05:06 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Won't work.
The actuator/selenoid has to be in the trunk. It needs to pull on the trunk release latch.
Those kits on eBay will work. Keep in mind that you'll need to wire in a SPST (single pole single throw) or SPDT (single pole double throw) automotive relay, if you want to trigger it with your alarm.
The aux. outputs on alarms are low current outputs, so you must use a relay.
"Skoolin' the unlearned!"
Old 03-23-2005, 10:57 AM   #4 (permalink)
How Ya Like Me Now?
so the actuator/selenoid has to pull on the release itself hmm(i still dont really see why i can have the actuator/selenoid pull on the trunk release cable, where the pull handle usually goes, so it replicates the action of pulling up?)
im not going to install the alarm myself so i can let the pros deal with that
so it looks like my inner pull handle should still work huh
98 V6 XLE
Old 03-23-2005, 05:31 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
Well the actuator/selenoid should be installed in the trunk.
You can install it that way, but I only way I can see it working is if you bolt the actuator/selenoid to the side of the seat, so that it pulls up on the lever.
I don't know about you, but I wouldn't want a big ol ugly selenoid bolted to the side of my drivers seat.
Yes, it'll still work
The manual trunk release lever inside the car will still work. Theres a cable that runs from the lever to the latch in the trunk, so its independent of the electric trunk popper actuator/selenoid.
Old 03-25-2005, 11:29 AM   #6 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
for the solenoid to work by placin in the cabin, the solenoid must be stationed and the cable insulator has to be stationed also. its stupid to do it that way, just mount it on the trunk itself.
some of the solenoid doesnt come w/ this one parts that needs to be rivetted into the panel. ask b4 ordering, the one w/o the rivetting part sux. just ask if it has a rivet in the kit and theyll know.
do not order them from www.partsexpress.com.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 03-25-2005, 12:22 PM   #7 (permalink)
How Ya Like Me Now?
ok, have you done this? not to sure what is entailed in riveting this to the panel
98 V6 XLE
Old 03-25-2005, 01:35 PM   #8 (permalink)
View pmohr's Photo Gallery
Just wondering, what's the benefit to having an electric trunk release as opposed to the regular pull release next to the driver's seat (other than being able to remotely trigger it with an aftermarket alarm)?
pmohr is offline   Reply With Quote
Old 03-25-2005, 01:51 PM   #9 (permalink)
How Ya Like Me Now?
thats the whole idea, when i get my alarm i can just hook this up. The shop that would install my alarm said they would charge 75, so im trying to save a buck or 2
98 V6 XLE
Old 03-25-2005, 08:00 PM   #10 (permalink)
Motorcyle Tech
Racer_Rodney's Avatar
View Racer_Rodney's Photo Gallery
the wireing can be a little tricky but its not too bad, remember to use good connections and solder when ever possible. I have this on mine and it works very nice when I have my daugter in one arm and groceries in the other (keys in hand) hit the button and I'm all good
I also wired in a mercury switch trunk light. It still puzzels me why it didn't come with one
CarDomain pics-->http://members.cardomain.com/racer_rodney
My WebSite------>http://rcarman.home.mchsi.com/
Racer_Rodney is offline   Reply With Quote
Old 03-25-2005, 08:09 PM   #11 (permalink)
How Ya Like Me Now?
do you have pics or anything, anything would be helpful
98 V6 XLE
Old 03-25-2005, 08:12 PM   #12 (permalink)
Motorcyle Tech
I can get some in the morning my wife is shopping with the hooptie now
