how to secure amp?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2005, 04:28 PM   #1 (permalink)
nicoj122
Guest
Posts: n/a
View nicoj122's Photo Gallery
how to secure amp??
hey guys, i have a question, i have my amp behind the rear seatback of my 05 double cab tacoma and its currently just sitting there, not secured at all.
now, id like to mount it, but am unsure what the best way of doing it is.
the thing is the bottom can sit flush with the back, but the amp is too tall to fit under the 'bump' on top. so its either mount it at an angle or make a spacer to put on the lower mounting spot.
my idea so far was to use those screws with the tip like a drill bit and just mount the amp at an angle without the spacer.
let me know what you guys think
Old 03-28-2005, 04:38 PM   #2 (permalink)
View thoughthard's Photo Gallery
Get creative with some spare particle board or plywood, and some carpet.
thoughthard is offline   Reply With Quote
Old 03-28-2005, 05:09 PM   #3 (permalink)
nicoj122
Guest
Posts: n/a
although that sounds good, i think i want something more simple. since its not on display or anything i just want to prevent it from flopping around the easiest way possible
Old 03-28-2005, 05:35 PM   #4 (permalink)
My easy way would be to get a scrap piece of wood a bit wider than the amp. Screw the two lower mounting points to the wood. Place the amp back in the seat opening. Screws the wood down with some vertical screws. Screw the top mounting points to the seat using horizontal screws.
Hmmm... does that make sense?
Old 03-28-2005, 06:13 PM   #5 (permalink)
Unrecognized
DMDrew812's Avatar
View DMDrew812's Photo Gallery
Double sided foam-tape?
'94 Camry
Full Alpine Type S system w/CDA-9847 HU & MRV-T420 amp (the amp is for sale ~$100)
Powered by The Cheat
DMDrew812 is offline   Reply With Quote
Old 03-28-2005, 08:02 PM   #6 (permalink)
cam2Xrunner's Avatar
Do you have any leftover wood from the enclosure you built? An amprack made out of MDF(or plywood) is the best way to go. You can cover it in vinyl to match the rear shelf.
If you don't want to go that route, get some L shaped brackets and bend them so that it lines up with the amp and the rear shelf.
Old 03-28-2005, 08:24 PM   #7 (permalink)
nicoj122
Guest
Posts: n/a
new idea...
how bout if i secure the amp to the plastic cover using screws, and then just use some washers on the back side to distibute the force?
basically this sounds like the easiest way to do it, and it seems to be a good idea. very simple and this way i dont drill into the metal.
Old 03-28-2005, 09:11 PM   #8 (permalink)
View toyocsd01's Photo Gallery
Get some velcrow with sticky tape on the back. Boom, done.
toyocsd01 is offline   Reply With Quote
Old 03-28-2005, 09:46 PM   #9 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
This is what I did in my Trooper. I just cut 2 pieces of compressed wood, one for each side. Then I screwed the amp down on it. Then I screwed from behind the plastic panel into the wood as opposed to screwing it into the plastic from the front where the amp is. Just an idea.
http://www.xclusive.bz
Old 03-29-2005, 12:25 AM   #10 (permalink)
nicoj122
Guest
Posts: n/a
thanks dna59 i think im gonna do some kind of an amp rack and screw in from the back like you said
Old 03-29-2005, 06:59 PM   #11 (permalink)
nicoj122
Guest
Posts: n/a
ok built the amp rack today.
basically just took a sheet of leftover 3/4" plywood and cut it to 9" tall and 13 or 14" across.
then i screwed the amp onto it and then screwed the board onto the plastic from behind using screws with washers.
worked out great, havent carpeted yet, but i was kind of in a rush. ill eventually get around to carpeting it.
