Removing passenger side corner paneling on 05 Taco - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2005, 11:36 AM   #1 (permalink)
View ZachM875's Photo Gallery
Anyone remove or know how to remove the corner plastic paneling that has the hand grips on the passenger side (or the drivers side for that matter) of an 05 Tacoma?
I need to route some wiring from the front of the ceiling over to the passengers side and then down past the glovebox to the center console.
ZachM875 is offline   Reply With Quote
Old 03-31-2005, 11:53 AM   #2 (permalink)
nicoj122
Guest
Posts: n/a
View nicoj122's Photo Gallery
first you pop off the plastic squares on the handle, then you remove the two bolts, remove the handle, and then just pry the plastic piece off, its held by clips.
if you need to route wiring behind the glovebox youll also need to remove the black plastic piece on the side of the dash. its the piece thats exposed when you open the door. this one is held on by clips so you just pry it off
Old 03-31-2005, 01:21 PM   #3 (permalink)
View SilverTacoma's Photo Gallery
How about removing headliner on 05' Tacoma dblcab?
Looks like this might be a good place to add this.
Just wondering what are the steps in order to remove the headliner on an 05' tacoma dblcab?
Thanks in advance!
SilverTacoma is offline   Reply With Quote
