my rear speakers in the car sound terrible... i need to replace them.. what kind of speakers should i get?
i think they are 6 x 9 in size... btw how do you remove the speakers?
i will also get a subwoofer and an amp.. what do you guys recommend for a good price?
i still have a stock am/fm cassette player in it.. and i need to remove it and install a cd player which i have... i dont know how to remove the cassette player.. any ideas...
ty
removing reaer speakers...pain in the ass. you have to remove the rear seat...the bottom, it pops up with a tug on it. Once out, the side cushions come out with a 12mm socket. Once off, 2 screws in the rear deck...phillips (they are hidden behind caps). The rear deck slides out and they ya go. they are 6 12" OEM...but a 6X9 will fit good as well. Removing the deck is easier, the trim piece around the radio can be pried out with a screwdriver...falthead, and then you have 4 10mm bolts holding the radio in...that is it on a gen 3. As for what to get...check around, everyone has an opinion. I went with JVC and MTX. PM me with probs
I'd also rec. replacing your front speakers with components and getting an external amp to power them. This will make the best improvement on the stereo system.
i read that pfd.. its pretty usefull.. i will try to take out the stock one but if i cant then i'll take it to bestbuy cuz they'll put in the new one for $15...
i just installed the cd player by myself.. apparently best buy charges $55 for labor and $20 for the kit lol... i just bought the kit and did it my self..
now i have a problem... the parking lights on my car wont turn on... they turn on when i open the door with my remote control... but they wont turn on if i manually try to turn them on from the inside.. and the light for the guages and the light on the gear wont turn on either...
what could that prob be... could it be a fuse?
Did you follow the installdr directions? Take another look at that and see if you wired it up wrong.
yea i did the wiring correctly... there isnt any lights wire in the radio....
but the dimmer on the left side of the steering wheel did control the amount of light to display on the stock radio...
the new cd player is working perfectly... just something wrong with the parking lights... they normally flash when you use the security alarm to open the doors... but just wont work if you try to turn them on from the inside..?
for the speakers............ i have to replace the speakers in the rear.. they sound horrible... so i will just get some cheap one's... and then i will get an exterior amp and 2 subs...
how about these subs : http://www.bestbuy.com/site/olspage....=1099396976115
they are pretty affordable..
for the radio i did find an orange wire which i cut of because i dont know what to attach that wire with...
I think stock radios and aftermarket radios use the dim function differently. Stock head units can accept dim by degrees, the dial used to dim the clock and 'meters on your dash worked for the HU as well. I think the only thing that aftermarket HUs will accept for dimming is whether or not the headlights are on. My Alpine HU doesnt even dim at all, not automatically.
I just tinkered with my alarm this morning. Toggle the Valet Switch on and off, or visa versa (the switch would be about at your left shin while driving.) My parking lights started working with the alarm after that.
'94 Camry
Full Alpine Type S system w/CDA-9847 HU & MRV-T420 amp (the amp is for sale ~$100)
If you're somewhat serious about your car stereo stop looking at crap from Bestbuy. What's your budget and what are you trying to get right now? Subs, amps, speakers?, what all do you own already.
