will it fit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2005, 11:18 PM   #1 (permalink)
View Oh_1_cam_LE's Photo Gallery
will it fit
Hey peoples....jus bought a 01 Camry LE for my wife...has the JBL system...well the radio is pretty worn out...I have a Pioneer DEH-P77DH (from old Tahoe) din and a 1/2 HU...will it fit in my cam or can I only swap it out for a din size or DD din...thanks for any info...
Oh_1_cam_LE is offline   Reply With Quote
Old 04-05-2005, 11:26 PM   #2 (permalink)
cam2Xrunner's Avatar
It should fit but, you are going to have a space left in there. You could probably fill in that space with the cover that the 01-04 Tacoma's have when they don't come with a CD player.
Old 04-05-2005, 11:27 PM   #3 (permalink)
Oh and check this out for help on bypassing the factory amp.
http://www.toyotanation.com/forum/t70082.html
Old 04-05-2005, 11:41 PM   #4 (permalink)
so the factory unit is a double din...well that sux...I jus wanted to put something in that was a little better than what is there...I have a radio jus sitting in the closet...so there will be alittle space left over...hmmm... I might jus try to put it in and see how it is gonna turn out...Thanx for the information...
Old 04-06-2005, 07:22 AM   #5 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
atually, with the space left over, you can cover it up with a piece of ABS plastic....that is what I use to fill gaps in an install.
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 04-06-2005, 10:25 AM   #6 (permalink)
I do have some ABS sheet..jus wasnt sure if the radio would fit..I have enough stuff around the house from other installs left over that I could fill the gap with..thanx for all the help...that is kewl that Toyota has a second harness to bypass the factory amp...guess Im gonna put the radio in on sat when I have more time..
Old 04-06-2005, 11:10 AM   #7 (permalink)
Knailgun's Avatar
cool, let us know how it worked out for ya
Old 04-08-2005, 08:30 PM   #8 (permalink)
does anybody have a din and a half (aftermartket) in their ride..or is everybody replacing with the din or the double din...if you have any pics..could you post them or email them to me...I think Im gonna have to fab something up...
Old 04-08-2005, 09:29 PM   #9 (permalink)
I've never seen a 1 1/2 Din stereo in a toyota. I think the only problem you will run into is the need to drill out new holes in the side brackets that hold the cd player so that it will match up.
If you look at a base echo or a base tacoma they come with an am/fm radio that is basically missing the top part that would be the cd player. This panel is exactly half din sized.
If you mount the 1 1/2 din stereo you have at the bottom of the 2 din opening, you'll have 1/2 din opening at the top where you would use the toyota 1/2 din panel.(you might need to drill new holes in the side brackets in order to get it to line up, you might not)
I looked for the 1/2 Din panel on ebay and didn't find it, so I would say go to the dealer, it probably only costs 10 bucks or so.
Old 04-08-2005, 09:35 PM   #10 (permalink)
I have been searching ebay for the past hour...I have searched the internet and countless other places...I made me some templates...for the radio cut size...I was thinking that I might have to fab the whole set up...Im gonna tear into it tomorrow...and see what it would require...to the bracket come off of the stock radio and you have to reuse them when you install an aftermarket...or the kit come with new brackets...I bought a install kit from wally world...but it will not work...it said Toyota but after I opened it..it is not for the camry..oh well...more research to do..thanks for the help..
Old 04-08-2005, 09:47 PM   #11 (permalink)
The brackets should work. I'm not sure whether or not you have to drill new holes for it to line up where you want it to.
Make sure you get a wiring harness like this one
http://www.cardomain.com/item/SCOTA02B?vq_id=none
Here's another idea, might not be feasible but
http://www.cardomain.com/item/SCOSK3
That's basically the addon that goes in Scosche kit pockets. It looks like it's half din sized. If it would work it would take up the space and serve a purpose.
Old 04-09-2005, 09:04 AM   #12 (permalink)
well...I just pulled the dash out and tried to test fit the din and a half..no fit...it is bout 1/2" to wide...I guess I will jus buy a din size and make it easier on myself..thanks for all the info....I guess I will but the din and a half back in the closet...hahaha
