DVC Ohmage "?" - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2005, 05:24 PM   #1 (permalink)
Unrecognized
DMDrew812's Avatar
View DMDrew812's Photo Gallery
DVC Ohmage "?"
simple question. I would spam it on someone elses thread, but w/e. I read up on different ways to link DVC subwoofers.. when you narrow a dvc (4ohmx2) sub to two ohms, the output on the amp increases.. but is there a degredation of sound quality or volume?
'94 Camry
Full Alpine Type S system w/CDA-9847 HU & MRV-T420 amp (the amp is for sale ~$100)
Powered by The Cheat
DMDrew812 is offline   Reply With Quote
Old 04-13-2005, 06:39 PM   #2 (permalink)
View OHWJaJae's Photo Gallery
Not really. Depends on the amp and what you're powering.. but generally no.
OHWJaJae is offline   Reply With Quote
Old 04-13-2005, 09:21 PM   #3 (permalink)
Unrecognized
DMDrew812's Avatar
We're looking at the Alpine SWS-1242D 300-900w sub, and likely the Alpine MRD-M301 Amp. The sub is 4ohm DVC (4+4) and the amp is rated at about 350wrms @2ohms. Stock Alternator (weak!) and Alpine's CDA-9847 HU as the brains of the operation.
'94 Camry
Old 04-13-2005, 10:05 PM   #4 (permalink)
TN Ass Man
DrtySthV6SE's Avatar
View DrtySthV6SE's Photo Gallery
the power teh amp sends to the sub will be greater because of less resistance, in turn it definately has the ability to be louder with more watts, the degration of sound quality would depend on the amp and the sub, the sub might not be able to handle the watts the amp sends it at a lower Ohm
the amp and sub you have listed should be fine at 2 ohms, im assuming 300 is RMS and 900 is max
Pioneer Premier, Elemental Designs, SoundSplinter, Resonant Engineering Audio, Stinger, Optima, Rockford Fosgate
DrtySthV6SE is offline   Reply With Quote
Old 04-13-2005, 10:06 PM   #5 (permalink)
You won't hear the difference on that setup.
Old 04-14-2005, 06:11 AM   #6 (permalink)
Unrecognized
DMDrew812's Avatar
got it, thanks
'94 Camry
Old 04-14-2005, 12:00 PM   #7 (permalink)
klaymen333's Avatar
View klaymen333's Photo Gallery
theres no reason to not wire your subs down to the lowest ohm rating your amps can handle (assuming you arnt overpowing your subs)
you get the most out of your amp
and the lower the ohms the louder it will be
....just dont put a one ohm load on a two ohm stable amp...
*sniff sniff* whats that smell??
05 Silver Tacoma dc TRD off-road
Diamond D7104 (on D9 tweets and D9 drivers)
Diamond D7402 (1600 watts on two Dual 4ohm TDX 12's)
jl 300/4 (bridged to hex drivers in kicks)
eclipse 8455
2500watts = 153.7 dbs
http://www.toyotanation.com/forum/t85694.html
http://www.cardomain.com/ride/836451
klaymen333 is offline   Reply With Quote
Old 04-14-2005, 12:43 PM   #8 (permalink)
Unrecognized
DMDrew812's Avatar
yeah alpine accepts only 2 and 4 ohm applications. Dont wanna fry nothin'
'94 Camry
Old 04-15-2005, 01:45 AM   #9 (permalink)
nicoj122
Guest
Posts: n/a
View nicoj122's Photo Gallery
dual 4ohm voice coils can be wired to 2, 4 or 8 ohms.
Old 04-15-2005, 01:56 AM   #10 (permalink)
cam2Xrunner's Avatar
You can get either 2 ohm or 8 ohm out of one 4 ohm DVC sub depending on how you wire it.
A dual 2 ohm can be wired to get 1 ohm or 4 ohm depending on how it is wired.
Everything changes when you use more than one sub.
http://www.jlaudio.com/tutorials/wir...dex.html#1dvcs
Old 04-15-2005, 07:51 AM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Agreed.
Dual 4 ohm wired in parallel = 2 ohm.
Dual 4 ohm wired in series = 8 ohm.
Only way to get 4 ohms is to run each coil individually, which is not recommended.
"Skoolin' the unlearned!"
Old 04-15-2005, 01:10 PM   #12 (permalink)
Unrecognized
DMDrew812's Avatar
yeah, i read about having 2 diff signals in one sub (like doing dual SVC, but with a DVC unit) bad idea
'94 Camry
