connecting more speakers then a amp is made for - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2005, 02:53 PM   #1 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
right now i have a 2 channel amp and i have 4 midrange speakers connected to it. if a add 2 more speakers can something go wrong.?
lucanhookup is offline   Reply With Quote
Old 04-15-2005, 03:04 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Depends how the speakers are wired.
I'm guessing that right now you have 2 speakers on each channel. And the speakers are wired in parallel or series.
So for now your running at 2 or 8 ohm stereo.
As long as the amp can handle the load and the speakers are wired correctly, I don't see any problems.
Just keep in mind that the amp is going to draw more current. It has to work harder to push 6 speakers instead of 4.
By the way, why do you have 4 mids?
"Skoolin' the unlearned!"
Old 04-15-2005, 04:56 PM   #3 (permalink)
word to ur mother
^ my front speakers and my rear speakers. and i really dont know what ohms are? and yea i do have 2 speakers connected at each channel.
Old 04-15-2005, 07:20 PM   #4 (permalink)
View finese1's Photo Gallery
You can't unless you do it in series. If you do it parallel definitely gonna over load the amp. Most speaker are 4 ohms. If you run 3 on 1 channel you going to be at 1 ohm or lower bridged. Kaboom is the last thing you'll hear from those speakers.
finese1 is offline   Reply With Quote
Old 04-15-2005, 09:14 PM   #5 (permalink)
klaymen333's Avatar
View klaymen333's Photo Gallery
if you are going to add another set i would add a 4 channel amp
its not necessarily a good idea to run 6 midrange speakers off of one two channel amp...even if you wire it correctly..sound quality is going to be iffy depending on speakers and amp
stereo speakers like to be run at 4 ohms
most amps degrade in quality when dropped to 2 ohms
this is fine for subs because the difference is not noticible
but for mids and highs, hooking up 6 speakers will cause a noticible difference than hooking up each speaker to its own channel (one set on the present amp and two sets on a four channel)
this is not to say you cant do it
it will sound better if you add another amp
to wire 6 speakers to a two channel: wire two parallel and one series to each channel, and i think that should put you at 6 ohms per channel....which means you are losing power from the amp...imo...its a bad idea ....more speakers and less wattage
if you want to add more speakers...add another amp
05 Silver Tacoma dc TRD off-road
Diamond D7104 (on D9 tweets and D9 drivers)
Diamond D7402 (1600 watts on two Dual 4ohm TDX 12's)
jl 300/4 (bridged to hex drivers in kicks)
eclipse 8455
2500watts = 153.7 dbs
http://www.toyotanation.com/forum/t85694.html
http://www.cardomain.com/ride/836451
klaymen333 is offline   Reply With Quote
Old 04-15-2005, 09:30 PM   #6 (permalink)
word to ur mother
thanks for ur help guys. but one more stupid q-wat are ohms and how do they effect ur sound system?
Old 04-15-2005, 11:38 PM   #7 (permalink)
View OHWJaJae's Photo Gallery
Ohms are the resistance in the circuit.
Think of it as being a type of current delivered from your amp. Your amp produces power, but will produce resistence based on the way you have your speakers wired up. If your amp can't handle the load, you can damage it or your speakers. As you lose resistence you gain power/wattage. Therefore the lower the ohm you're running the more power you will be sending. Just make sure your amp/speakers can handle it.
OHWJaJae is offline   Reply With Quote
Old 04-16-2005, 08:06 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
http://www.ohmslaw.com/ohmslaw.htm
http://science.howstuffworks.com/question501.htm
