what type of fuse do i need? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2005, 10:25 AM   #1 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
my freind just bought a amp on ebay and i want to know what type of fuse does he need and how many amps does it have to be.
this is the amp
http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting
thanks for ur help
lucanhookup is offline   Reply With Quote
Old 04-17-2005, 10:35 AM   #2 (permalink)
View virtualkuz's Photo Gallery
100 amp wafer, and run 4 gauge wire from the battery, don't use 10 or 8 gauge.
2005 Corolla XRS Silver Streak Mica
2005 Kawasaki Z750S Candy Plasma Blue
1993 Kawasaki EX500a Luminous Polaris Blue
virtualkuz is offline   Reply With Quote
Old 04-17-2005, 10:38 AM   #3 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
think 80 would work aswell
800=14.4(A)
55.5=A
100 amps would be too much rite?
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 04-17-2005, 11:12 AM   #4 (permalink)
View OHWJaJae's Photo Gallery
50 amp fuse for the amp, at your alternator put another fuse at the same rating as your alt.
OHWJaJae is offline   Reply With Quote
Old 04-17-2005, 12:09 PM   #5 (permalink)
How Ya Like Me Now?
what?
50 amps wouldnt be enough(i know amps never run at their true power rating, but being so close would blow the fuse)
theres no fuse at the alternator, because there is no conection with the alt, hes not doing the big 3
98 V6 XLE
Old 04-17-2005, 12:30 PM   #6 (permalink)
Originally Posted by Anshu
what?
First of all, my bad about the alternator... I'm tired. I meant the fuse at the battery to be the same as your alt. And yes, 50amp fuse is all he needs for that amp.
Good luck with the install Lucan, thanks for the catch Anshu.
Old 04-17-2005, 12:36 PM   #7 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Visonik... never heard of this brand...
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 04-17-2005, 03:34 PM   #8 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
It's crap.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 04-17-2005, 04:37 PM   #9 (permalink)
klaymen333's Avatar
View klaymen333's Photo Gallery
the fuses by the battery are mostly for shorts...50 or 70 will work
take a look at the fuses on the amp add the numbers together...it should be a good estimate
05 Silver Tacoma dc TRD off-road
Diamond D7104 (on D9 tweets and D9 drivers)
Diamond D7402 (1600 watts on two Dual 4ohm TDX 12's)
jl 300/4 (bridged to hex drivers in kicks)
eclipse 8455
2500watts = 153.7 dbs
http://www.toyotanation.com/forum/t85694.html
http://www.cardomain.com/ride/836451
klaymen333 is offline   Reply With Quote
Old 04-17-2005, 04:51 PM   #10 (permalink)
word to ur mother
thanks for ur help guys. yes i know the amp is crap but he doesnt want a sick system.
Old 04-17-2005, 06:05 PM   #11 (permalink)
That fuse is to protect your alt. That fuse is to prevent you from sending too much current and to prevent a fire.
Old 04-18-2005, 12:17 PM   #12 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
um there are two fuse on the amp already, take a look at what they are add em together and thats what you need near the battery, unless your running more than one amp.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 04-19-2005, 03:34 PM   #13 (permalink)
klaymen333's Avatar
if it was to protect the alt...why is in-line with the battery?
it is to prevent too much voltage from going down the line but typically it is from shorting the circuit....same reason houses have breakers...they DO prevent too much voltage...which 9 times out of 10 is because of a short
you sir are a hat
eclipse 8455
Old 04-19-2005, 04:26 PM   #14 (permalink)
you sir are a hat
The battery is basically a pump of power, however, the alternator is what is driving your system while the engine is running. The battery is on the same circuit and therefore acts as a reserve...
The fuse at the battery is placed there to prevent too much power from going through the circuit. If too much goes through you're liable to destroy the wire, thus causing a fire or damaging your alternator if you try to pull more power out of it than it can handle. That fuse is meant to be a safety for the circuit as a whole before your vehicles electrical system gets damaged and to possibly prevent a fire.
And eddie was right, if you're only running one amp you only have to use a fuse rated at what your single amp is rated at, kills two birds with one stone. However, I usually place an additional fuse near the amp for what the amp is rated at. It isn't necessary to do it this way and will cost you an extra 5 bucks, but it's just a habit. This way if you ever were to change out amps or add an amp/distro block you don't have to worry about what's under the hood (unless you need to upgrade you power wire). This also keeps most of your troubleshooting in the trunk and not at two ends of the vehicle.
And just an FYI, the fuse isn't protecting you from too much "voltage."
Old 04-19-2005, 06:06 PM   #15 (permalink)
klaymen333's Avatar
my bad amperage/current.....
if you read my first post...i do say "add up the numbers of the fuses on the amps and its a good estimate"
i never said the battery would blow up...i said it would cut the power if the wire shorted
eclipse 8455
