I would sell it, and get an alternator, also an oddysey battery. Top it off with the Big 3 upgrade and you should be set. EDIT NM I see you already have those last two handled. Looks like all you need is the alternator.
Take advantage of this group buy at sounddomain. In case you missed that second link in that post above, here it is
http://forum.sounddomain.com/ubb/ult...c;f=5;t=009993
A 220 amp alternator is like 189 right now as part of the group buy.
The mr.alternator alternators are 240.00 for a 150 amp alternator.
The obvious choice is the Iraggi alternator. You can get the "amputator" 220 amps max 175 amps idle alternator for $339.00 minus 25%= 255.00
That's the way I would go. Irragi makes a very good reliable alternator.
