No aw125t, but I did find a aw1251t:
AW1251T
12” NATURAL SOUND WOOFER
45 oz. Strontium Magnet
Power Handling: 400 watts RMS
Frequency Response: 24Hz - 1kHz
Efficiency: 92.1 dB
PHAT Foam Surround
Non-Pressed, Non-Transfer Paper Cone
KM3’ Coated for Virtually No Cone Distortion
2” 4-Layer ASV Voice Coil
Dual 4 Ohm
2 or 8 Ohm Operation
Mounting Dimensions: Depth; 5 1/4”
Hole; 10 7/8” Diameter; 12 1/2”
MULT-CONNECT Lug Lock Terminals
If this is what you have, I would wire the coils on each sub in series. Each sub will then be at 8 ohms.
Then wire the 3 subs in parallel to each other. This will give you 2.67 ohms. 8 ohms / 3 subs = 2.67 ohms.
Wire the subs to the amp in bridged mode. Usually left + and right - on the amp, check your amp to be sure.
Make sure your amp will do 2 ohm mono.
"Skoolin' the unlearned!"
