Originally Posted by z-lite
I don't know the tech specs of audio wiring but will the receiver cut off a frequency before sending the signal out to the amp preout?
Yes, if the headunit has a built in crossover.
I looked at the manual of the receiver and it says 55Hz for the low sound so I want to know if the deep bass(lower than 55Hz) will be sent out to the amp for amplification.
Yes, if its a 55Hz low pass crossover. Meaning everything from 55Hz and below will be outputted.
Theres low pass, high pass, band pass, and full range. Crossover wise.
