Corolla LE 1998 Amp Power Wiring - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2005, 10:38 AM   #1 (permalink)
View vseth's Photo Gallery
I've got a Toyota Corolla LE 1998. Just got an 4 guage amp wiring installation kit, and now need to get to the battery through the firewall, and prefer to not drill any new holes through the firewall. Would prefer going through existing grommets, if possible. On the passenger side in the trunk, i did notice about a two inch cutout hole in the metal with some wiring coming out. Tried fishing my way back from this opening with no luck. If somebody's done an amp install on their corolla, you input is appreciated.
vseth is offline   Reply With Quote
Old 05-03-2005, 07:01 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
No Corolla here, but are you wiring from back to front? It's easier to wire from front to back, at least I think so, and run the cable along the door sill panels. From the front, you can always take the DRIVER front wheel well panel off, with the wheel off, and fish the cable through the existing grommet. That's the best location since you don't need to stretch the power cable across the engine bay since the battery is on the driver's side. If you just try and look for places to snake, it won't happen easily.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 05-04-2005, 05:01 PM   #3 (permalink)
The two inch cutout hole that I was referring to in my post is actually in the passenger side in the Engine Bay, I'd mistakenly mentioned it as "passenger side in the trunk". Are there options other than removing the wheel well cover, for running the 4 Guage from the battery through the firewall.
Old 05-04-2005, 07:10 PM   #4 (permalink)
Luc
There might be, look for where the steering column comes in from the engine bay. My friend ran his 4-gauge power through the rubber grommet there in his '00 Camry.
Old 05-19-2006, 09:20 PM   #5 (permalink)
View cobra5813's Photo Gallery
Driver side grommet vs. center grommet
I have a 1997 Corolla. If I'm going to go through the driver side grommet (the open hole he referred to...), should I open the wheel well? I'd like to go through the center grommet, but it seems like it's sealed on the external (hood) side. Any advice?
cobra5813 is offline   Reply With Quote
