need help with buying a new amp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2005, 10:41 PM   #1 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
Arrow need help with buying a new amp
ok i want a 4 channel amp that can put out about 120watts rms per channel and 2 channel amp that can push about or more then 750 watts rms at each channel. the 2 channel amp i need for my 2 kicker l7's that are 4ohms. how many ohms are the iridium 6.2 component speakers so i can get a amp that can give about 100 watts rms at there ohm level.
the most ill spend on both amps is about $1.00-$800.00
thanks for ur help guys.....later
lucanhookup is offline   Reply With Quote
Old 05-06-2005, 11:11 PM   #2 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
good luck finding a 2ch with 750x2, may be better off running 1 ch per sub
you upgraded yer alt yet?
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 05-06-2005, 11:30 PM   #3 (permalink)
word to ur mother
^ yea that kicker amp seems perfect but yea thanks for wishing my luck..lol...no i havent upgraded my alternator yet. soon i will. but how about a 750+ 2 channel amp
if i get 2 1 channel amps i have to get a custom amp rack for them cuase ill be running 3 amps
Old 05-06-2005, 11:36 PM   #4 (permalink)
How Ya Like Me Now?
yea i think you will have to, even Zed stuff isnt going that high
98 V6 XLE
Old 05-07-2005, 12:03 AM   #5 (permalink)
cam2Xrunner's Avatar
So did you decide on going with the DLS Irdium 6.2(2 way) or did you want to go with the 3 way with the dome midrange? 6.3?
They are 4 ohms btw.
My opinion. get the 6.3 set, an amp that will do at least 75 watts rms X4 and a seperate 2 channel amp that will do around 125 watts rms X 2
Run the 4 channel amp active, one channel to each tweeter, one channel to each dome midrange.
On the other two channel run each channel to each 6.5" midbass.
Are you still thinking about w7's? May I suggest two IDMAX's instead? Half the cost, I'd say the IDMAX has better SQ, while the W7 might get a little louder, the difference is that the IDMAX are alot more efficient.
Another good sub right now is the Ascendant Avalanche
http://www.toyotanation.com/forum/t77975.html
watch that video with the two 15's
Loud enough for ya?
Old 05-07-2005, 04:56 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
I'm with Anshu. Good luck finding a amp that will do 750x2. Amps that will put out that kinda power are usually mono blocks.
Are your subs 4 ohm svc (single voice coil)? If so wire the 2 subs in parallel and get a amp that will put out the power you need @ 2 ohm mono.
"Skoolin' the unlearned!"
Old 05-07-2005, 10:22 AM   #7 (permalink)
word to ur mother
Loud enough for ya?
yea im still going with the irdium 6.3 speakers on my camry but im putting everything that i have on my camry onto this accord that my dad just bought. we are going to put the 6.2's on the accord and the 6.3's on the camry. the camry will still have the 3 jl audio w7 13inch subs but im putting the 2 L7'S that it has right now into the accord. i need 2 new amps for the mids and subs. im currently running about 400watts to each kicker sub so i want a amp that can run them to there RMS.
Old 05-07-2005, 10:24 AM   #8 (permalink)
word to ur mother
the subs that im using are 4ohms dvc. there 2 kicker solobaric 12inch L7'S
i think im just going to have to run 2 seprate amps for the subs
Old 05-07-2005, 03:47 PM   #9 (permalink)
Oh ok they're DVC, sweet that means you can wire them so the amp will see a 1 ohm load.
Look for an amp that will do 1300-1400 watts rms @ 1 ohm
Wire the subs like this
(option 1)
If you want to save some money you can get a Hifonics Brutus BX2005D, that will do a little less than 200 watts rms @ 1 ohm, just turn the gains down some, and it'll stay cool.
Less than 350 shipped on ebay.
An eD nine.1 will do 1200 watts rms @ 1 ohm. That's also around 350
Old 05-07-2005, 03:51 PM   #10 (permalink)
A DLS A3 would be a nice match for the Iridiums. Or you can get a 4 channel amp and run them active, but if you don't have the right proccessing for the accord, I'd just go with a reg 2 channel.
How about an eD nine.2 for the 6.2's and an eD nine.1 for the Kicker L7's, that would be 100 watts rms X 2 to the 6.2's and 600 watts rms to each sub(1200 watts rms @ 1 OHm)
Or you can get the Nine.4 and run the 6.2's active.
http://www.edesignaudio.com/forum_discount.php
Old 05-07-2005, 03:54 PM   #11 (permalink)
word to ur mother
cool thanks how about a kicker kx1200.1 amp. how many watts are the subs going to get with option 1 using the kicker amp?
^kicker amp
Old 05-07-2005, 04:00 PM   #12 (permalink)
word to ur mother
i was also thinking of just getting 2 kx1200.1 and run one to each sub but since there rated at 1200watts rms at 1 ohm how many watts will the subs get since there 4 ohm?
Old 05-07-2005, 04:16 PM   #13 (permalink)
^kicker amp
600 watts each rms, if the amp isn't over or underrated.
Old 05-07-2005, 04:21 PM   #14 (permalink)
That would be a waste of money and space. Each sub would have to be wired in series and you'd get a final 2 ohm load to each amp
You would be sending each sub 600 watts, which would be the same as using one of those amps and running it at 1 ohm, to get 1200 watts rms between the two of them(600 watts each)
Old 05-07-2005, 10:40 PM   #15 (permalink)
Grenaded piston
88 LE's Avatar
You mean parallel.
4 ohm dvc sub wired in parallel = 2 ohms. If it were wired in series, you'd get 8 ohms.
