im upgrading my audio system and will need a new battery as well. Here is the system specs...6x9's infinity kappas in the back 300 watts...infinity kappas 6.1perfects up front 400 watts...two 12" alpine type-x subs...3000 watts each...1 kicker amp for the 6x9's and 6" front speakers 300 watts...and 1 JBL bp1200.1 amp for the subs which is 1200 watts...so the question is...whats the best battery for such system? optima yellow top? stinger? please post some models that will fit a 94 camry v6...thanks all.
i had a 2 ohm stable jbl that i ran at 1 ohm for over 2 years before i sold it
so you sir dont know what you are talking about
jbl makes good amps...they just make crap speakers
and abovethelaw
dont go infinity....way too harsh and not enough midbass
get some alpines or something
as for a battery....pft....you need a bigger alternator...if you are running that kind of wattage on a stock alternator, its just gonna damage your charging system
a bigger battery will help for a short time, but when it starts to die and the alternator has to do all of the work, it will be stressed
what amps are you running?
3000 watts per sub im assuming that what their peak rating is...
btw dont pay attention to peak power ratings...they mean nothing
look for rms ratings
that supposed 3000 watt PEAK sub is really only 1000 watt RMS sub
same thing with amps...dont be fooled by a 1000 watt amp if it says 1000 watts peak
that means it probably only does 4-600 watts if that
Thanks for the help all. I will get a better alternator shortly. Klaymen...your right about those infinity speakers. They dont produce enough midbass but they do get really loud though.
I said they were good, I just mentioned one guy said that he's seen quite a bit go through his shop, but then again, he's also seen quite a bit of other amps go through his shop too
Im considering buying one of these
People, just answer the questions the original poster asked, no need to go into what's better or bad about other equipment. No one wants to hear about your personal prejudice, keep it to yourself. If you "heard" about something, prove it by providing a link to back up your claim or personal experience with it.
I'd go with either the Odyssey pc1200mjt or a Stinger SP1000(pretty much the same battery)
These are cool because you wouldn't need to stretch or replace the battery cable as you would for an Optima. The post is closer to the original location.
If you don't want to spend the 200+ on a H.O. Alternator, you can also look into getting a stock altenator from a Highlander with the V6 Tow Package option. This is a 130 amp alternator, and you might be able to pick one up pretty cheap with an exchange.
Otherwise there's a bunch of good H.O. alternators available. There is a group buy going on the Sounddomain forum for Excessive Amperage Alternators.
