i need help with my eq - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2005, 08:42 PM   #1 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
ive been fucking around with my eq's setting for a while and i can never get it to sound good, what i need to know is what do all these HZ and shit do so i can set it to the music i like, my eq is a 11 band.........................thanks
lucanhookup is offline   Reply With Quote
Old 05-24-2005, 12:17 AM   #2 (permalink)
View rawdawg's Photo Gallery
The purpose of an EQ is to tailor the IN CAR frequency response so that the music hitting your ears sounds the way the artist/producer/engineer wishes for you to experience it. That is one way to approach it.
Another way to approach it is by using the EQ as a sonic paintbrush and making the system response however you see fit. That is the way my ghetto based friends approach it.
From left to right, each band represents a point in the frequency response. It would go from super low to low to middle to high to super high. If your music is too bassy, cut down on the low bands. If your music is too crispy, cut down on the high bands. If you can't hear the singer, boost the middle bands.
Generally, there is a more correct curve than others that will make all your music, regardless of genre, sound really good. From there you can adjust for your peculiar listening habits.
For example, I've DJ'd for nearly 20 years of my life and have gone clubbing for the same amount. My ears are probably not as sensitive as others. In my case, my system is tuned to be heavier handed than most.
Now the above is an elementary way of describing an EQ, so if you need a more detailed description, please feel free to PM cam2xrunner.
1988 Camry
Occasionally washed
rawdawg is offline   Reply With Quote
Old 05-24-2005, 12:24 AM   #3 (permalink)
cam2Xrunner's Avatar
Old 05-24-2005, 04:44 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The best way to adjust an eq is to use a RTA (real time analyzer).
http://industrialaudiocontrol.com/pr...50&l1=5650&l2=
Otherwise just adjust it however you like.
"Skoolin' the unlearned!"
Old 05-24-2005, 11:37 AM   #5 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
If you cant afford a RTA, all you need is a SPL meter, test tones of each frequency (IASCA disk), a pencil and paper. You run each test tone and write down the dbs it is putting out, once you've gone through all the frequencies, you notice some will be higher some lower, adjust the those particular frequencies to flatten up the overall sound. This is a starting point, once you flattened your response (will most likely sound terrible), adjust it to you liking. The main thing is you want to adjust those major peaks and dips.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 05-24-2005, 09:02 PM   #6 (permalink)
You know what's funny. The general consensus is that a flat response is yucky sounding. Other than my issues with my sub and the roll off of my waveguides, my frequency response is fairly flat. And guess what? I like it.
This is what happens when you listen to Bunny and Tigra's "We love the cars, the cars that go boom" too loud at too young an age.
1988 Camry
Occasionally washed
