Originally Posted by Corollacrazy42
i try and look for the (VBR) or Variable Bit Rate, so that it rips the music at its highest standard from the cd
VBR has to do with how a mp3 file is compressed. The bit rate varies instead of the whole file being at 128kbps, 192kbps, etc...
It has nothing to do with ripping audio from a cd.
i have a program to change the bit rate of MP3's but not WMA's, which most of my music is.
Changing the bit rate is not gunna do much. The file size will be smaller/bigger, but the quality goes down or stays the same.
Lets say you have a mp3 thats 128kbps. You change the bit rate to 256kbps, its still gunna sound the same cos the original file is at 128kbps. You can't put back whats not there to begin with.
If your concerned about quality, you need to rip the song off a cd then compress it.
I use EAC (exact audio copy) to rip. LAME w/RazorLame (gui frontend for LAME) to compress into a mp3.
http://www.exactaudiocopy.de
http://jthz.com/~lame
http://www.dors.de/razorlame/index.php
Mostly everything that I rip is compressed at 256kbps, 44.1khz, stereo.
Don't use joint stereo or forced joint stereo, its whack.
