how much power will this amp give my subs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2005, 05:47 PM   #1 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
ok i think im going to ditch the 2 13inch w7's and go for 2 kicker 15inch dvc l7 subs but i need a amp for it, what i was thinking of getting was a kicker kx2500.1 amp. how much power will the subs get and how do i wire them?
lucanhookup is offline   Reply With Quote
Old 05-28-2005, 06:02 PM   #2 (permalink)
View thoughthard's Photo Gallery
Dual 4-ohm voice coils?
thoughthard is offline   Reply With Quote
Old 05-28-2005, 07:24 PM   #3 (permalink)
word to ur mother
^yup
Old 05-28-2005, 07:37 PM   #4 (permalink)
You could do this for a 4 ohm load total...
14.4V = 1500 watts, or 750 watts per sub
12.5V = 1200 watts, or 600 watts per sub
Old 05-28-2005, 07:39 PM   #5 (permalink)
or run one of the subs, if it can handle the power...
14.4V = 2500 watts
12.5V = 2000 watts
Old 05-28-2005, 08:46 PM   #6 (permalink)
The Other White Meat
terrastrife's Avatar
4 ohm amp? tahts kinda poor erm.... can it run 1 ohm?
terrastrife is offline   Reply With Quote
Old 05-28-2005, 09:01 PM   #7 (permalink)
word to ur mother
the amp is 2ohm stable
Old 05-29-2005, 04:30 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Your post makes no sense.
Running a amp at 4 ohm vs 1 ohm = better sq, more efficient, less heat.
I have a mono block (Linear Power 8002SW) that runs at 4 ohm mono or 8 ohm mono. So by your terms I guess its poor, even though its a $1300 amp.
"Skoolin' the unlearned!"
Old 05-29-2005, 08:39 AM   #9 (permalink)
running a lower (or higher -- i mean 1 ohm) would be louder
i used to run my DLS D1000 at 0.5 ohms, steady as a rock :P
