sub amp combo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2005, 05:25 PM   #1 (permalink)
Bad@$$
madmax3208's Avatar
View madmax3208's Photo Gallery
sub amp combo
i am looking at two infinity 12 inch subs and am trying to find an amp. any suggestions.
madmax3208 is offline   Reply With Quote
Old 06-09-2005, 05:28 PM   #2 (permalink)
View PDC4runner's Photo Gallery
personally ive allways been a fan of JL audio.. but thats just me...
what are ure subs rated at??
PDC4runner is offline   Reply With Quote
Old 06-09-2005, 05:39 PM   #3 (permalink)
Bad@$$
madmax3208's Avatar
what do u mean rating? im new at this
Old 06-09-2005, 05:41 PM   #4 (permalink)
Bad@$$
madmax3208's Avatar
i also have a one channel head unit so i think i can only get a monochannel amp
Old 06-09-2005, 05:43 PM   #5 (permalink)
View Ryan 25's Photo Gallery
power handling, how many watts do they use? If I'm not mistaken, Those subs are around 300RMS and 1000-1200 max. You're going to want a big amp, match your wattage output numbers to your sub input numbers (300RMS sub = 300RMS Amp). You can use smaller amps, but you'll run into clipping problems at high power, I know, I ran 2 12" Infinity's with a 200W amp, what a waste of my subs.
Ryan 25 is offline   Reply With Quote
Old 06-09-2005, 05:46 PM   #6 (permalink)
Bad@$$
madmax3208's Avatar
ur right. how good are mtx amps? ive heard they are good but am not sure
Old 06-09-2005, 05:47 PM   #7 (permalink)
Subs and speakers are typicaly rated for how mutch power (wattage) they can handle they should have both an RMS rateing and a Peek rateing...
RMS prety mutch means average...
Peek.. means well.. peek...
soo.. if you have two subs rated at say... 150watts RMS .. you would want and amp that is rated to put out around 300watts RMS...
(anyone please call BS on me if im missin something..)
also.. my personal opinion when it comes to car audio... Ive found that typicaly you get what you pay for.....
hope this helps in some way...
im a little brain dead at the moment... stupid work deadlines...
Old 06-09-2005, 05:48 PM   #8 (permalink)
Bad@$$
madmax3208's Avatar
http://www.circuitcity.com/ssm/Infin...oductDetail.do is this any good
Old 06-09-2005, 05:53 PM   #9 (permalink)
id say it would work..
how good.. no idea...
..err.. wow that was useless help.. sory..
Old 06-09-2005, 09:06 PM   #10 (permalink)
Bad@$$
madmax3208's Avatar
if i have a one channel head unit do i have to get a 1 channel amp
Old 06-09-2005, 09:12 PM   #11 (permalink)
View OHWJaJae's Photo Gallery
What impedence are your speakers?
I believe most Infinity speakers are 4ohm, if you have two.. that amp work work. What's the model number of the speakers you have or are going to get?
OHWJaJae is offline   Reply With Quote
Old 06-09-2005, 09:24 PM   #12 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
you need a 2 ohm stable amp to accomidate the two infinities.. i was gonna buy them and still buying 2 10" infinitiy kappa perfects with an MTX Thunder 942 amp which should put about 470 watts to each.. the head unit doesnt have 1 channel, that would mean it would only be playing one speaker.. it has 4 channels and then aux outputs on the back to accomidate for other things such as amps and iPod connection.. knowing which kind of headunit you have would help greatly let us know.. oo btw that MTX is well strong enough to power your two and is about 285 at www.sounddomain.com right now.. check it out
Corollacrazy42 is offline   Reply With Quote
Old 06-09-2005, 09:38 PM   #13 (permalink)
Bad@$$
madmax3208's Avatar
i have an Alpine CDE-9843 CD Player, and i want to get two 6.5 inch infinity speakers and two 6x9 inch infinity speakers.
Old 06-09-2005, 09:51 PM   #14 (permalink)
Bad@$$
madmax3208's Avatar
http://www.circuitcity.com/ssm/MTX-S...oductDetail.do this is cheap but is it any good
Old 06-10-2005, 12:26 AM   #15 (permalink)
by speakers I meant subs.
