OK it looks like you are using Sounddomain. To figure out how ohm configurations work, click on the subwoofer wiring guide. That will tell you how to wire them and what ohm load you will get.
If you were to get a dual 2 ohm subwoofer you can wire it so the amp will see either a 1 ohm load or a 4 ohm load.
If you were to use a dual 4 ohm sub, you can wire it to see only a 2 ohm load.
Now you are going to want to use an amp that does 750 watts rms at either 1, 2 or 4 ohms, depending on which sub you get.
The cheapest way to do it will be to get a class D monoblock amp that will do 700-800 watts rms at 1 ohm.
What's the actual budget that you would like to stay under? DOn't say no budget, because there are 10,000 dollar amps out there and I'm sure you don't want a 10k dollar amp
