Powering components with monoblock amps - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2005, 02:50 AM   #1 (permalink)
Wazzaaap!
View mauibuilt59's Photo Gallery
I know its possible and i know people have done it before. How do you power your components with two monolock amps? on the deck, theres the front preamp outputs which are red and white...one is right +/- and the other is left +/-. So how would i hook up the two monoblock amps to the deck?...using only one (either the white or red) rca cable?
92 Camry v6 (3vz-fe)
mauibuilt59 is offline   Reply With Quote
Old 06-23-2005, 03:05 AM   #2 (permalink)
cam2Xrunner's Avatar
What kind of monoblock amp is this? Is it a class D?
Old 06-23-2005, 12:43 PM   #3 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
What do you mean DLS A3 are monoblock amps, but they still have a red and white output, so what are you asking here.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 06-23-2005, 12:53 PM   #4 (permalink)
klaymen333's Avatar
View klaymen333's Photo Gallery
no Class D on components...2 monoblocks...may be fine as long as they arnt class D
05 Silver Tacoma dc TRD off-road
Diamond D7104 (on D9 tweets and D9 drivers)
Diamond D7402 (1600 watts on two Dual 4ohm TDX 12's)
jl 300/4 (bridged to hex drivers in kicks)
eclipse 8455
2500watts = 153.7 dbs
http://www.toyotanation.com/forum/t85694.html
http://www.cardomain.com/ride/836451
klaymen333 is offline   Reply With Quote
Old 07-01-2005, 04:10 AM   #5 (permalink)
Wazzaaap!
Well, any monoblock amp. I have an xtant A4004T biamped into a pair of mb quart pwe's. I also have a xtant 121m laying around not doing anything. So I was wondering if I bought another 121m then I could use two of those to power my components w/ 125 watts a piece. I am just a little bit confused about the wiring aspects of the setup.
Old 07-01-2005, 11:02 PM   #6 (permalink)
I wouldn't do it. You're better off using your 4 channel and wiring the components active.
What headunit are you using? Maybe instead of wiring bi-amped(which isn't bad) you can use the cd players onboard crossovers to wire them active-depending on your headunit.
What are you using for a sub amp? Maybe that will work better than what you are using?
Old 07-03-2005, 07:20 PM   #7 (permalink)
Wazzaaap!
I have an old alpine deck, 7892, and running a rockford power 450s. The crossover settings from my alpine EQ, deck, and amps dont go high enough that I can use their crossover settings. I was just thinking of more ways that I could get more power for my components
