Corolla 97 alarm - HELP NEEDED
I need to plus this aftermarket alarm (Hitech Ht-455) Plugging it is not a problem except I don't have a clue about wire colors. Maybe someone can help me
The actual colors written in this message are the one from the manual so coming out of the control module of the alarm.
Can someone tell me on which wire / location to plug it
Thank you
Black ----- Chassis Ground (That I guess I can find :-)
Red ----- 12V
White ----- Hazard Lights (O/P + 5 A)
White ----- Hazard Lights (O/P + 5 A) (there is two it is not a repeat)
Black/White ----- Open Dormer (O/P -500mA)
White / Blue ----- Engine Cap
Green / Black ----- Rolling Up Windows (O/P -500mA)
Red / White ----- Trunk (O/P -500mA)
Green ----- Unlock (O/P -500mA)
Blue ----- Lock (O/P -500mA)
Brown ----- Siren (This one I can figure out too)
Blue ----- Foot Brake
Yellow ----- ACC (l/P +) ===> Stops before ignition switch then goes into the 4 pin module included with alarm
Orange ----- Goes directly into the 4 pin module included with alarm
Green ----- Negative Door Switch (l/P-)
Purple ----- Positive Door Switch (l/P+)
Red Black ----- Main light )l/P+
Thick Yellow (coming out of 4 pin module) ----- Ignition coil
Thick Yellow (coming out of 4 pin module) ----- 12V
