Good SQ/Thumping Sub, and matched amp? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2005, 05:42 PM   #1 (permalink)
Georgian Pickup Drifter
Mushroom_Toy's Avatar
View Mushroom_Toy's Photo Gallery
I have a 91 Pickup and I'm looking for a good 10" subwoofer and amp for a good price. I want to have a sub that has great sound quality, and have something that I will not have to turn up too much for a little bass. Was looking at something maybe in the 500-2000w range, but thinking a 400w might be best paired with a good corresponding amp. I want something that will have great sound quality with great bass at low volumes, and something where I can turn it up and it'll make my ears bleed. This is asking a lot form just one 10, but I know with a proper setup and properly designed box tis is possible.
I was looking at the Alpine Type X, and the Power Acoustik MOFO subs, but I'm thinking thats just too much.
Also was looking at the Image Dynamics IDMAX subs, and the Ascendant Audio Atlas subs, but not sure these will be ear bleeding subs when turned up. I know they're praised for good sound quality, but I don't know how much "thump" they will produce.
Any suggestions are appreciated. Basically what I'm looking for is a great SQ/powerful 10" subwoofer and a good amp. Price is not a concern at the moment, but I will not have a huge budget when I go to buy these.
-:- NGK -:- American Racing -:- Denso -:- Mobil 1 -:- KYB -:- Belltech -:-
2nd Gen Camry Parts for sale or trade. Pm for Details.
Need 89-94 4x4 or 4runner parts.
Mushroom_Toy is offline   Reply With Quote
Old 06-30-2005, 08:05 PM   #2 (permalink)
Audiophile on a budget
View TakeABao's Photo Gallery
Well you need to narrow things down a bit man...
500w to 2000w opens up a pretty broad range of possibilities... Also, it looks like you have a '91 Toyota truck, so my next question is, where do you want to mount your sub(s)/amp? Does it have to be a certain depth? Will it fit anywhere??
Would you mind posting pictures of the cabin of your truck (you have no back seats obviously..) and where you might think a sub would fit??
People are going to recommend you a lot of stuff, but if you're going for pure SQ, I'll go ahead and throw out some things paying no particular attention to price... (This is all stuff I've heard personally)
* Stereo Integrity Magnum D2 (I've only heard the older gen...they were pretty f-in' good)
* IDMAX
* IDQ (if budget is an issue)
* JL W6
* Elemental Designs Ov.2
* Soundsplinter RL-i
I'll think of others eventually...
/////ALPINE | Helix | SOUNDSTREAM
TakeABao is offline   Reply With Quote
Old 06-30-2005, 08:45 PM   #3 (permalink)
Ok here's where it's going:
This is right in the middle of the truck behind the seat over the transmission. I plan on making a fiberglass box that will span about the span of the pic, or about 2-3ft wide on the back of the truck. I'm going to aim the sub up about 20 degrees from where back meets the floor. This will more than likely be a temporary setup until I get buckets and make a center console.
The amp will more than likely be mounted to the left of the sub, directly to the flat sheetmetal or in another fiberglass enclosure for a floating amp. So the amp can be pretty big, if need be.
Yeah I've looked at the Elemental Designs and IDMAX and I like them, and heard the produce great SQ, but I'm wondering if they'll also hit quite hard when called upon.
Old 06-30-2005, 08:56 PM   #4 (permalink)
Yes. Both those subs dont' take a lot of power to get moving.
Since you haven't give me a budget to work with, I'll throw a couple more out there:
W7
RE XXX
More along the lines of "SQL" drivers with tremendous output. Wait for Cam2XRunner, Eddie, or mcv to come on -- I can almost guarantee they'll reaffirm some of the stuff I said and recommend some other options...
Since, you're building an SQ setup, I'm going to assume you already know what components (and also what amp to run them) you're going to get...?
Old 06-30-2005, 09:03 PM   #5 (permalink)
At the moment I'm unsure of an amp. I really need to get my sub picked before I buy my amp. I have or can get most of the components that I'll need. Right now I'm just looking for a good hard hitting SQ sub and some amp combos, if I don't pick an amp. I really like the ED amps...they look like great amps.
I guess what I'm looking for is a SQ sub with SPL qualities.
EDIT: Oh, and has anyone heard of Lanzar subs? They looked like good subs and pretty cheap too, but I haven't heard them or heard about them so I can't verify if they are good or not.
Old 07-01-2005, 12:19 AM   #6 (permalink)
cam2Xrunner's Avatar
Only thing made by Lanzar to consider are the Optidrive amps. Everything else isn't really up to par with some of the names being thrown around in this thread.
Have you figured out the max mounting depth you will be working with?
Every sub mentioned here is awesome. The main thing you need to consider before buying a sub is the mounting depth available and the available internal airspace of the enclosure you will be building.
Old 07-01-2005, 01:52 AM   #7 (permalink)
Most mounting depth I can get max would be close to 15 in. As for airspace I can build that according to the sub I get, since I'm doing a fiberglass enclosure
Old 07-01-2005, 02:04 AM   #8 (permalink)
15" ?!?! You are refering to depth right? Not Diameter.
Old 07-01-2005, 01:24 PM   #9 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
ID Max 10 would would great for application, in a slot port box. Maxes, dont require alot of power to make em move (min 600 watts), if you want a little more output consider a Brahma 10, still maintain SQ of course.. The max requires a bigger box than the brahma, the brahma wont really start moving until it gets about 1000+ watts.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 07-01-2005, 04:21 PM   #10 (permalink)
Cam I can basically have the depth as much as I need to a certain point, as long as it doesnt hit the seat. It's probably less because I just gave an estimation earlier.
Old 07-02-2005, 06:09 PM   #11 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
wait which sub from imagedynamics is there best? there all meant for sq right? thanks alot like always.
lucanhookup is offline   Reply With Quote
Old 07-02-2005, 06:37 PM   #12 (permalink)
Originally Posted by Jeremy Mullins of ID
I could see where you think that the Max is our better model, because of it's price. In our world, we don't make a speaker that doesn't sound "good". We didn't design our speakers on a "good" "better" "best" ideology. All of our lines are specifically designed for different listeners and applications. And then the price points are spread out for obvious reasons (mostly because a max is EXPENSIVE to build).
Sure the max will have plenty of SQ, but in my opinion it's not our best sounding speaker. I has a great mix of power handling, efficiency, excursion, and refinement that make one bad speaker. But what happens when you don't want a 1,000 watt amp and you don't want 36lbs (per speaker) and you don't have 8" of depth to mount this thing... Different speakers different applications. I would suggest taking a look at the IDQ line for moderate levels of extremely accurate bass, the ID line for average joe daily driving at higher output levels of accurate bass. In any event, you can call us and speak to the tech, you might even get a hold of Eric (owner/principle engineer) who takes tech calls from time to time. Get some input and go.
FYI the IDQ 10's Fs is 26Hz
For those that don't know;
Fs = resonant frequency of the driver
It depends on what you are looking to get out of the system and what amount of power you have available.
Two IDQ15's will give you a good mix of SQ and SPL
Old 07-02-2005, 07:30 PM   #13 (permalink)
^ Do you think one 10 would give me as much SPL that I might want?
Old 07-02-2005, 07:33 PM   #14 (permalink)
word to ur mother
which ones are u getting cam2xrunner? i saw some on sounddomain that handled 1000watts rms
Old 07-02-2005, 08:19 PM   #15 (permalink)
Not sure how much you are looking for but if SPL is a concern I would probably go with the IDMAX or a similar output sub.
Some other good choices to look at Soundsplinter RL-i 10"
Oz Audio Matrix Elite
DAYTON 10" TITANIC MKIII
Those last two will work great off around 400 watts. With either or these I'd go with a class ab 2 channel amp bridged for better sound quality.
