I meant to use all the channels of the 300/4 on the front components. One channel to each tweeter and one channel to each mid. Ditch the supplied passive crossover in the component set.
This is called wiring active. You can adjust the crossover frequencies to your liking on each channel from the amp, and set the eq from the headunit. This will also let you use the Eclipses time alignment feature to compensate for the pathlength differences between the tweeters and the mids.
Kinda complicated doing it this way but the end result is much better.
For sound proofing foam, you can get ensolite foam from Rick @
www.raamaudio.com or search ebay for different deals on closed cell foam. Ensolites probably the best way to go though unless you can find a good deal on a slightly thicker closed cell foam. Maybe a neoprene foam like this
If you want to use rear speakers, power them of the headunit's rear channels.
