d5 amp - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-04-2005, 09:42 PM   #16 (permalink)
cam2Xrunner's Avatar
Originally Posted by madmax3208
i need two y splitters so that all four of the rca inputs are filled up. i also need a wire to connect from the batterie to the amp and from the ground(chassis) to the amp. the other wires that connect from the speakers to the amp are called what?
Speaker wire.
Check out www.knukonceptz.com they're pretty cheap. Also check out www.partsexpress.com
In the Ultimate Audio Sticky there is a post by Phi which goes over Basic Amp Install Instructions
I would use 4 gauge wiring from the battery to the trunk(or wherever you are going to mount the amps) then use a fused distribution block to split it to 8 gauge to each amp. Then use 8 gauge wiring on each amp for ground wire.
The front two channels of the amp go to the speakers. The rear channels to the mids. Adjust crossover like in the other posts.
Old 07-04-2005, 10:57 PM   #17 (permalink)
Bad@$$
madmax3208's Avatar
View madmax3208's Photo Gallery
aight i think i got it
I love my camry even tho its slow as hell
1996 Camry le 5sfe
tokico struts, whitline sway bar, ractive strut bar, weapon r intake, alpine cda9855( it was a 9821), idq 15, d5 300, d3 400, (seas 7" woofers, lpg tweets), and prolly the only cam with a cb radio
madmax3208 is offline   Reply With Quote
Old 07-05-2005, 04:21 PM   #18 (permalink)
Bad@$$
madmax3208's Avatar
whats the difference between 1m 2m and 6m in rca wires
1996 Camry le 5sfe
Old 07-05-2005, 11:18 PM   #19 (permalink)
1 M(Meter) = 3.2808399 feet
2 meter = 6.56167979 feet
6 meter = 19.6850394 feet
