d5 amp - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2005, 11:57 PM   #1 (permalink)
Bad@$$
madmax3208's Avatar
View madmax3208's Photo Gallery
d5 amp
just got my d5 amp and my d3 is on the way. i am makin sure for the last time that i go tthe right wires. i need two y splitters a 4 channel kit and a two channel kit, dont know what else. this is the system im talkin about btw http://toyotanation.com/forum/t83133-5.html
I love my camry even tho its slow as hell
1996 Camry le 5sfe
tokico struts, whitline sway bar, ractive strut bar, weapon r intake, alpine cda9855( it was a 9821), idq 15, d5 300, d3 400, (seas 7" woofers, lpg tweets), and prolly the only cam with a cb radio
madmax3208 is offline   Reply With Quote
Old 07-03-2005, 12:17 AM   #2 (permalink)
cam2Xrunner's Avatar
How does it look? Got any pics by chance?
Old 07-03-2005, 12:22 AM   #3 (permalink)
Bad@$$
madmax3208's Avatar
ill post some tommorow
1996 Camry le 5sfe
Old 07-03-2005, 07:20 PM   #4 (permalink)
Bad@$$
madmax3208's Avatar
i dont know exactly where the bandpasss is located
1996 Camry le 5sfe
Old 07-03-2005, 09:05 PM   #5 (permalink)
Bad@$$
madmax3208's Avatar
anybody?
1996 Camry le 5sfe
Old 07-03-2005, 09:21 PM   #6 (permalink)
Can't see clearly in the Pic, got a better one?
Old 07-03-2005, 09:45 PM   #7 (permalink)
Bad@$$
madmax3208's Avatar
h/o
1996 Camry le 5sfe
Old 07-03-2005, 10:02 PM   #8 (permalink)
Bad@$$
madmax3208's Avatar
http://photobucket.com/albums/v442/m...SC01786dsf.jpg
1996 Camry le 5sfe
Old 07-04-2005, 12:42 AM   #9 (permalink)
Are you using a camera phone? It's really hard to tell by the picture.
Is the manual that came with the amp any different than this one?
http://www.diamondaudio.com/products...0.4-030403.pdf
I believe in order to put it into bandpass mode you turn the HPF and LPF on then select your crossover points for the mids(which will be wired off the rear channels 3-4)
Re-read the info here http://www.toyotanation.com/forum/sh...079#post760079
The front channels should have the HPF on and the LPF off. The rear channels should have both filters on.
I'm pretty sure that's how it works, but you might want to get tech help from Diamond just to be sure.
Old 07-04-2005, 01:17 PM   #10 (permalink)
Bad@$$
madmax3208's Avatar
ok the dials on the amp dont go to 2:30 for the l/p
1996 Camry le 5sfe
Old 07-04-2005, 01:18 PM   #11 (permalink)
Bad@$$
madmax3208's Avatar
it starts at 2:00 and goes to 4:00
1996 Camry le 5sfe
Old 07-04-2005, 01:33 PM   #12 (permalink)
Bad@$$
madmax3208's Avatar
goes counter clockwise btw
1996 Camry le 5sfe
Old 07-04-2005, 01:34 PM   #13 (permalink)
You are going to want to experiment with the settings. Try it with the mid crossed over at around 3K hz(right about 3:50) You gotta go by what sounds best to your ears. The goal is to have the tweeters and mids blend in well together and have a high soundstage. You want the music to sound like it is coming from the hood of your car.
Old 07-04-2005, 07:16 PM   #14 (permalink)
Bad@$$
madmax3208's Avatar
so i have never set up an audio system before. i dont understand which wires connect to what and what i need to buy
1996 Camry le 5sfe
Old 07-04-2005, 08:50 PM   #15 (permalink)
Bad@$$
madmax3208's Avatar
i need two y splitters so that all four of the rca inputs are filled up. i also need a wire to connect from the batterie to the amp and from the ground(chassis) to the amp. the other wires that connect from the speakers to the amp are called what?
1996 Camry le 5sfe
