EDIT: Read latter posts, changed setup due to buying a 5 ch.
I bought another PPI Art amp. This one's a A300. I scrapped the idea of using ribbons. I don't want to give up my footspace. There already isn't much as it is anyways.
I'm going to use the PPI A100.2 I have on LPG 25NFA tweets in the A pillars(35 bucks each). For the mids I'm not sure yet which. I think i'm going to be using a dome midrange in the factory tweeter spot or in the A pillars fiberglassed maybe. I'm considering the Dynaudio
MD140/2 3" Dome Midrange
If I can't find those for a decent price I'll go with the DLS UR2.5 Dome midrange.
http://www.dls.se/english/speakers/UR2,5.htm
What's cool about the Dynaudio and DLS Midrange' is that they are both in their own sealed chamber. They can be put in a very small space and do not require an enclosure for them. This helps alot in A Pillar installations.
The PPI A300 will be used for the midrange speakers.
For the midbass I'm going to take advantage of the 6x9" opening and use an 8" Midbass. Most likely the Peerless XLS 8"
http://www.madisound.com/pdf/peerless/830491.pdf
These will be powered off an A600 or A600.2 PPI art amp.
For the sub I'll be using a 15" IDQ in a sealed MDF enclosure. Until the IDMAX15 comes out, then switching to that
I'll be using another A600/A600.2 for the sub as well.
For a headunit, I think I'm going to step up with the Pioneer P9 Combo along with the carputer to 10.4" Xenarc screen.
So I have like 1/8 of all the equpment I need
I've got two of the amps I need, and the speakers will be ordered tuesday
