Power rating RMS/Peak at 4Ohm RMS at 12 Volt
4 x 60 Watts + 1 x 170/250 Watt
Power rating 2 Ohm RMS/Peak at 13,8 Volt
4 x 80 Watts + 1 x 250/500 Watt
Total harmonic distortion
< 0,009%
Signal to noise ratio
> 100 dB
Damping factor
> 50 - 800 adjustment
Frequency range
20 Hz -20 kHz +/- 0,2 dB
Dimensions (H/W/D)
> 1.25" x 7.8" x 17"
Check out JL Auido amps, been using them for 3 years now and no problems just good clear loud sound. The only problem I had was the pass side seat has a bar running across the bottom of the seat, could not put an amp under the seat.
I've had JL slash amps before-300/4 and 500/1. They were nice, and had good crossovers.
My whole system is going to cost about 850 bucks. That's how much two JL amps cost new. Then another 500+ for a W7, then wiring, box, sound proofing, etc...
I like the clear cover on the amp your getting, wish JL would do something like that. Im trying to find a turbo charger for my truck but nobody is making it yet. Have you heared of anything.
Im still trying to post pics but Im not the best computer operator in the world, but Im learning and trying, I'll get it right soon enough. Thanks for the info on the turbo.
