vibrations from subs - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2002, 02:23 PM   #16 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308675
Originally Posted by Bigshoguns
On a off topic Would IS300 rims fit a 98 Camry Le. if yes ne one have a set for sale.
THX
SS
They will fit, but the offset is wrong. You will need spacers and longer wheel studs to make them fit, I believe. Is it worth it? That's up to you.
-Charlie
Old 10-05-2002, 07:10 PM   #17 (permalink)
Call me DR. DIY or SHGUN
View Bigshoguns's Photo Gallery
Oo Wow. I rather just buy a set of BBS or POLO. By the Way waht GEN is a 98 camry
Bigshoguns is offline   Reply With Quote
Old 10-05-2002, 08:06 PM   #18 (permalink)
white90dx's Avatar
1983-1986 1st gen
1987-1991 2nd gen
1992-1996 3rd gen
1997-2001 4th gen
2002-on 5th gen
8)
-Charlie
Old 10-07-2002, 07:31 PM   #19 (permalink)
View crazy_camry's Photo Gallery
i'll have to try this peel and seal or something similar. i don't have the cash for expensive sound deadening stuff. i wonder if they'll have the stuff down where i live. what was it supposed to be used for?
crazy_camry is offline   Reply With Quote
Old 10-07-2002, 07:36 PM   #20 (permalink)
white90dx's Avatar
I believe its for roofing. Just look for an asphalt based product with a really sticky backing. That'll be about the same as standard Dynamat. (but not as good as some other options)
-Charlie
Old 10-07-2002, 07:46 PM   #21 (permalink)
yeah thanks. i accept i'll never get rid of all the vibration but i do need to stop it as much as possible. its unbearable. especially the rear bumper, that must be shaking itself to pieces.
Old 10-08-2002, 02:05 AM   #22 (permalink)
rayray's Avatar
View rayray's Photo Gallery
a picture is worth a thousand words...
here's the stuff that i used. it's called FoilSkin by a company called Bakor. found it at Home Depot for, i think, about $14 for a roll 23 cm by 3 meters. you can find it in the roofing section. it has a very adhesive backing and it doesn't smell all that bad like other products. it's moldable (that a word?) and waterproof. which it should be as it's really used to seal air and water leaks around corners, pipes and vents.
props to machy for the idea. i knew it was out there but didn't go hunting for it until i saw pics of his install.
-rayray
rayray is offline   Reply With Quote
Old 10-08-2002, 09:34 AM   #23 (permalink)
NICE!!! that's similar thing that i used. Yes Props to machy.
Old 10-08-2002, 11:33 AM   #24 (permalink)
View rpj1984's Photo Gallery
THANKS for the pics..i am going to Home Depot as soon as i get home from work...i am going to lay that stuff down wherever i see metal in my trunk
ryan
rpj1984 is offline   Reply With Quote
Old 10-08-2002, 12:45 PM   #25 (permalink)
View mach_y's Photo Gallery
Yup. Go to the roofing section. It is aluminum backed sticky asphalt. Comes in rolls 6 inches wide most often. It is specifically used on the seam of a roof (where one side meets the other at the top of the roof). Works perfect in cars. Look at my webpage to see how I did my doors with it. Can't beat the price.
mach_y is offline   Reply With Quote
