Speed Sensor Wire?o5 Tacoma - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2005, 11:40 PM   #1 (permalink)
WINDIGO's Avatar
View WINDIGO's Photo Gallery
ok i just installed a avic -n1 in my 05 tacoma,but i have no clue where the speed sensor wire is?someone in the forum told me it was under the dash to the far left the easyiest wire to get to?what color is the wire?and im guessing under the driver side dash?can anyone help me here?
WINDIGO is offline   Reply With Quote
Old 07-23-2005, 11:58 PM   #2 (permalink)
Audiophile on a budget
View TakeABao's Photo Gallery
I'm not too sure there'd be a lot of people here who can help you. There aren't a whole lot of new-gen Taco owners on here and there are even fewer with AVIC N1's...
You best bet would be to make a post on...
www.elitecaraudio.com
www.sounddomain.com (forums)
Or...simply take it to your local shop and have them take a look. Sorry I wasn't too much help...
/////ALPINE | Helix | SOUNDSTREAM
TakeABao is offline   Reply With Quote
Old 07-24-2005, 12:28 AM   #3 (permalink)
WINDIGO's Avatar
thanks i will check that out
Old 07-24-2005, 01:06 AM   #4 (permalink)
cam2Xrunner's Avatar
I PM'ed one of the mods at TS who has access to all the wiring diagrams, so hopefully I can get an answer for you shortly.
You might also be interested in this little trick. It should work for your N1.
http://forum.elitecaraudio.com/showt...hreadid=114910
Old 07-24-2005, 01:10 AM   #5 (permalink)
WINDIGO's Avatar
thanks,i apreciate the help
Old 07-24-2005, 01:12 AM   #6 (permalink)
Self Proclaimed Genius
View SilverStreak05's Photo Gallery
Green wire - black 13 pin connector on the fuse box, pin #5
SilverStreak05 is offline   Reply With Quote
Old 07-24-2005, 01:21 AM   #7 (permalink)
WINDIGO's Avatar
so i take it look behind the fuse box and ill see what im looking for?heres a stupid questin but you say connector 13 can you even see the number on the connector.im gonna take a look here even though its 11:21 at night.
Old 07-24-2005, 01:21 AM   #8 (permalink)
SilverStreak05, do you happen to have the diagram for future references? Did you use one from TS?
Thanks.
Old 07-24-2005, 01:33 AM   #9 (permalink)
WINDIGO's Avatar
ok i seen the connectors on the front of the fuse box,ill look at it better tomorrow when theres actually light
Old 07-24-2005, 10:17 AM   #10 (permalink)
WINDIGO's Avatar
i didnt see a green-black wire on a connecter in the front of the fuse box(driver side)but ill look again,i may be blind
Old 07-24-2005, 10:51 AM   #11 (permalink)
I'm pretty sure that connector is on the back side of the fuse box, which means you'll have to take it out. 2-3 bolts IIRC, easy to do.
What I mean by 13 pin is you're looking for a plug that can accept 13 wires. That doesn't mean it will actually have 13 wires in it, just 13 places. The one you're looking for is black in color, most of them are white. Once you find the right connector, look on the backside and you will see the numbers, they're hard to see but they are there.
I get all my wiring info from www.the12volt.com. You can find a techsheet for the 2005 Tacoma here. I used that one to install my alarm. It doesn't list the VSS wire, but it's still a good resource for wiring information.
