"The Big 3" - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2002, 04:38 PM   #31 (permalink)
banned.
View martingouda's Photo Gallery
HAHAHA......go cry in the corner the rest of us don't want to hear it...you gotta see your posts up there trying to say it's good to drain power and that if dimming dosnt occur you cant have a good system
guy for real if you think you have more audio knowledge than me then my i suggest you try to post things that are true and can be backed up.....
I HAVE DONE COUNTLESS SYSTEMS....many of them on this forum....my own car has 10 speaker with amps custom wired and mounted not to mention two tv's a PS2 and tones of custom detailing and tuning from bass blockers to noise filters and believe me the wiriing is FLAWLESS and once again this is something that most of the people that have seen my car can't tell you.....i don't know your abilities first hand but as far as i can figure from your writing i think you need to take into account what people are going to assume based on your attidude....and if you think you have some sore of authority then i challenge you to call up fish man audio and ask if they have heard of you....maybe that will bring you back to reality because thier systems often cost more than the cars they put them in and believe me there is NEVER dimming problems...even if they need 5 batteries and 3 alternators with individual caps side mounted to each amp.
i dont know about you man but frankly i think this argument is pointless...read this whole post and try to find where i started trash talking and wwhat i was saying before that....
it was simple....THE BIG THREE IS A MYTH....and won;t help dimming anymore than a cap will (and a cap isn't for dimming either you dummies)
if you want to argue the above point i'll give you a hundred reason that i am right and you are wrong and i'll back up my fact with source refrences and give you the site to go to and people to call that can assure you that you are WRONG...
however if you just want to keep crying like a wunderbitch then pleay go out side and ask the first person you see to kick you in the balls because i have no need to spend my time on the net explaining to you and the rest of the peeps on this board why you deserve a good punting.
martingouda is offline   Reply With Quote
Old 03-11-2003, 03:56 PM   #32 (permalink)
View 92v6camry's Photo Gallery
try this my friend has 2-JL Audio 13.5" W7's and 2-JL Audio 1000 watt monoblock amps in his celica now thats a drain on the charging system
92v6camry is offline   Reply With Quote
Old 06-27-2005, 11:39 PM   #33 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
how about building me a budget system lol
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 06-28-2005, 11:20 AM   #34 (permalink)
Got SQ?
eddiem67's Avatar
View eddiem67's Photo Gallery
sorry martin but I have to disagree with you, the big 3 helps improve current from the alt to bat to amps. Why put in a 200 amp alt and feed the current throught an oem 8awg wire, you are choking the system, when an amp gets a high current demand the 8 awg wire will not supply the bat, so the bat will eventually drain, the amp will constantly run hot because it is now working twice as hard to maintain voltage. Think of a bucket of water getting fed through a straw or through a hose, the hose is going to get more water faster. Big 3 is a simple economical way to produce more current to the amp for systems that dont require more amps than the alt can produce.
Iraggi Alt ->SVR ->Eclipse ->Tru Technology ->DLS / Image Dynamics / Marv Enclosure / Rammat
Gen 4 V6
For Sale: Adire Audio Sadhara Sub System, Bryston SP1 Video Switcher, Totem acoustics speakers
eddiem67 is offline   Reply With Quote
Old 06-28-2005, 11:37 AM   #35 (permalink)
The Cool Guy
well adding a 8 awg wire from alt to bat including a fuse will help it anyhow since the stock engine already has the alt to bat wire.
Old 06-28-2005, 11:39 AM   #36 (permalink)
Got SQ?
eddiem67's Avatar
correct
Gen 4 V6
Old 06-28-2005, 01:09 PM   #37 (permalink)
Unrecognized
DMDrew812's Avatar
View DMDrew812's Photo Gallery
goodness.. cant we all just get along? Both sides have points here, theres no reason to negate another's solution. A bigger pipeline (doing the big 3) will allow the alternator us stock folks have to feed the battery at higher efficiency, to a point, but a stronger alternator will have a lager theoretical "feed-rate," assuming then pipeline is wide enough to meet electrical demands. Doesnt make wonder a queerbate, and doesnt make martin an idiot.
This cyber-flaming, however... :P
'94 Camry
Full Alpine Type S system w/CDA-9847 HU & MRV-T420 amp (the amp is for sale ~$100)
Powered by The Cheat
DMDrew812 is offline   Reply With Quote
Old 07-01-2005, 03:02 AM   #38 (permalink)
The Cool Guy
a 4 gauge wire supports up to 125 amps? or something like that while 8 is 50.....
125 amp stock fuse in my box.....so i'm guessing the alt is 125 volts or something?
