Voice Coil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2005, 04:08 PM   #1 (permalink)
Simple.
View Schmiess's Photo Gallery
Voice Coil
what exactly is voice coil? And what's the difference between dual 2 and dual 4? Is it just the Ohm resistance? and does that have to match up with the amp? (with the whole "75x2@4 ohm" deal)
-Mike
Schmiess is offline   Reply With Quote
Old 07-28-2005, 06:04 PM   #2 (permalink)
cam2Xrunner's Avatar
I would explain it, but it's so much easier to give you a link
http://www.jlaudio.com/tutorials/dvc/index.html
Old 07-28-2005, 10:25 PM   #3 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
It's basically just an electromagnet that slides in and out of the big permanent magnet that is visible on the back. You usually can't see the voicecoil without taking the sub apart.
That link has a lot more info though.
Pb is offline   Reply With Quote
Old 07-29-2005, 01:48 PM   #4 (permalink)
Simple.
So getting a dual 2 or dual 4 voice coil doesn't really matter? It's just preference? Or does it need to be compatible with the amp or anything?
-Mike
Old 07-29-2005, 02:06 PM   #5 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Ideally, the resistance (ohm rating) of your sub(s) should compliment your amps to use it's power as efficiently as possible (without damage). Depending on the number of subs, the resistance, # of voice coils (dual vs sinlge) and configuration (parallel vs. series)...you wanna pick the right set up for your amp.
Here are some configurations with impedence;
http://www.jlaudio.com/tutorials/wiring/index.html
Do you have an amp already? How many subs are you planning on running?
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 07-29-2005, 02:14 PM   #6 (permalink)
Simple.
Not yet but I'm planning on getting the Diamond D5300.4 Here are those specs
• 37.5W x 4 @ 4 Ohm Stereo
• 75W x 4 @ 2 Ohm Stereo
• 150W x 2 Bridged @ 4 Ohms
And I'll be getting 2 6.5" subs and I don't know whether to get the dual 2 or the dual 4 VC.
-Mike
Old 07-29-2005, 04:56 PM   #7 (permalink)
TN Ass Man
DrtySthV6SE's Avatar
View DrtySthV6SE's Photo Gallery
well 2 dual 2ohm sub can be wired to, .5, 2, and 8 ohms
2 dual 4 ohms can be wires to 1, 4, and 16 ohms
so really either would work with your application since your power is about the same running stereo 2ohm and mono 4ohm
edit: and i like your avitar, Strong Bad rules
Pioneer Premier, Elemental Designs, SoundSplinter, Resonant Engineering Audio, Stinger, Optima, Rockford Fosgate
DrtySthV6SE is offline   Reply With Quote
Old 07-29-2005, 05:28 PM   #8 (permalink)
Simple.
Rad, that's exactly what I needed to know. Thanks.
And thanks.
-Mike
