distribution block fuses - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2005, 11:53 PM   #1 (permalink)
Bad@$$
madmax3208's Avatar
View madmax3208's Photo Gallery
what fuses do i need to get for a knukonceptz distribution block, one 4guage to two 8 guage
I love my camry even tho its slow as hell
1996 Camry le 5sfe
tokico struts, whitline sway bar, ractive strut bar, weapon r intake, alpine cda9855( it was a 9821), idq 15, d5 300, d3 400, (seas 7" woofers, lpg tweets), and prolly the only cam with a cb radio
madmax3208 is offline   Reply With Quote
Old 07-31-2005, 12:03 AM   #2 (permalink)
cam2Xrunner's Avatar
The amp's onboard fuses are 60 amps, so you can match that with 60 amp fuses in the distribution block.
Then in your inline fuse near the battery use a 120 amp fuse. .
Old 07-31-2005, 12:27 AM   #3 (permalink)
Bad@$$
madmax3208's Avatar
do i just connect the 4 gauge to the batterie directly or do i need something else, what i have now is a 4 guage wire 8 gauge wire 4channel rcas 2 channel rcas, a distribution block, d5 amp and a d3 amp, and an idq15. any other dodads i need to get immediately or in the near future, and since i dont have the mids or the tweets can i just hook the d3 up to the idq15 for now and just use that. im guessing i would still be bridgeing the sub, but would that be enough power to the sub? thanks
1996 Camry le 5sfe
Old 07-31-2005, 01:42 AM   #4 (permalink)
You need to install an inline fuse in the power wire less than 18" away from the battery.
http://www.partsexpress.com/pe/showd...number=263-619
You can hookup the sub amp without installing the 4 ch yet.
