jl cleansweep - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2005, 03:13 AM   #1 (permalink)
View anoiel's Photo Gallery
jl cleansweep
i was just on jl website and they have something called clean sweep dose anybody know what it dose couldnt make sense of it when reading it
anoiel is offline   Reply With Quote
Old 07-31-2005, 03:26 AM   #2 (permalink)
Audiophile on a budget
View TakeABao's Photo Gallery
Factory headunit + cleansweep =
It adds all the features an aftermarket head unit would but w/o the complexity of custom fiberglassing and wiring. For somebody with say...an RX-8...the CleanSweep is going to be perfect since mounting a DIN-sized headunit requires A LOT of custom fabrication.
/////ALPINE | Helix | SOUNDSTREAM
TakeABao is offline   Reply With Quote
Old 07-31-2005, 03:50 AM   #3 (permalink)
cam2Xrunner's Avatar
The purpose of the JL Clean Sweep is to cancel out any factory EQ settings the manufacturers have preset into the factory stereo to compensate for the factory speakers and acoustics. It's job is to send a "clean" signal to your external processors and amps.
It's basically a highly advanced line level convertor. You run your speaker wire into it, then install the calibration CD into the headunit,and set the voume at 75 % play the CD and about 20 seconds the JL cleansweep's internal equalizer will adjust the factory preset eq settings. Then send a clean signal through RCA's.
For a regular system this is definitely not needed. For a very high end system you would benefit from this.
Unless you are doing a very high end install, just get one of these NE-774V
The only feature the JL Cleansweep adds that an aftermarket deck would give you is auxilary inputs.
Another thing to note is that you are supposed to use the Cleansweeps independant Volume control, and not the factory headunits.
Old 07-31-2005, 05:52 PM   #4 (permalink)
thank you for the information
