is this bridging the sub, if i have a d3 400.2 amp and an idq15 v.4 is this how i wire it
I love my camry even tho its slow as hell
1996 Camry le 5sfe
tokico struts, whitline sway bar, ractive strut bar, weapon r intake, alpine cda9855( it was a 9821), idq 15, d5 300, d3 400, (seas 7" woofers, lpg tweets), and prolly the only cam with a cb radio
1996 Camry le 5sfe
1996 Camry le 5sfe
1996 Camry le 5sfe
Ok cool, now on the amp it will tell you what outputs to use, iirc it is the left channels positive and the right channels negative. You do not use the other outputs.
well i hooked it all up and it dont work. do i have to have a remote wire? right now i have a 4 gauge conected to a distribution block which only has one of the fuses connecting it to the 8 guage because im not using the other connection, the 8 guage is goin to the amp in the 12 v and then a 8 guage wire is goin from the ground to the chassis (took paint off) the light is not turnin on what the fuck is goin on?
1996 Camry le 5sfe
Yes you need to use a remote turn on lead. On the back of the headunit there will be an ACC or " Remote" Turn on lead. Run a 18-22 gauge wire from there to the amp.
Also be sure to set your crossovers to LPF on and set it around 100hz and play with it from there, I'm guessing probably around 60-83 hz will be best.
what if i took 16 gauge speaker wire and use only half of it
1996 Camry le 5sfe
1996 Camry le 5sfe
