Remote Wire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2005, 02:31 AM   #1 (permalink)
View oschris2005's Photo Gallery
Remote Wire
I have an '05 Corolla S, and I am hooking up a 250 watt amp and a Kicker CVR 10 to my stock radio. I have everything hooked up, and it will work right. The only problem is that I don't know where to hook up the remote wire so that it doesn't drain the battery when the car is off. In other words, where do I hook the remote wire to so that the amp is only on when the car is?
oschris2005 is offline   Reply With Quote
Old 08-05-2005, 02:32 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
You can splice it into the cig lighter or power outlet.
2007 Camry 2.4L 5M
Old 08-05-2005, 02:37 AM   #3 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397685
View RningOnFumes's Photo Gallery
^^ x2....i did that and i also included a switch between the lighter and the amp because i knew there would be times when i wanted to listen to the radio without having the engine on.
---got a toggle switch from radio shack
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 08-05-2005, 02:49 AM   #4 (permalink)
cam2Xrunner's Avatar
You can also use the ACC turn on lead on the back of the headunit. It should be a thin light grey wire.
Old 08-05-2005, 02:52 AM   #5 (permalink)
The cig lighter/power outlet is on when the car is in ACC position (engine off)
Also, I suggest a 1-2A fuse on the wire.
2007 Camry 2.4L 5M
Old 08-05-2005, 03:05 AM   #6 (permalink)
Ninja-rator
i don't know about you gen 5/ 5.5 but in my gen 3.5...i know it is because sometimes i would pump my tires...and the cig lighter is exactly where i get the power from when i turn the key to ACC
