Speed Sensor Wire..05 Tacoma - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-05-2005, 11:46 AM   #1 (permalink)
View realw5's Photo Gallery
I'm having a hard time locating the speed sensor wire to tap into. I've looked up the 05 tacoma wiring diagram and it says it's either a purple/white or red/yellow wire, neither of which i've been able to locate. Can anyone please help me out, as I need to hookup my speed sensor for my NAV unit.
realw5 is offline   Reply With Quote
Old 08-05-2005, 12:12 PM   #2 (permalink)
Luc
View Luc's Photo Gallery
Ok, try this.
Fuse box, black 13-pin plug, pin 5, purple/white. Or, also found at the ECM behind the glove box, second plug from the bottom, pin 8.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 08-06-2005, 03:05 PM   #3 (permalink)
What color is the Pin 8 behind the glove box? I see a red/yellow one, and hooked my multimeter up using the resistance and get nothing.
Old 08-07-2005, 04:48 PM   #4 (permalink)
Luc
It should be purple/white as well. Why are you checking for impedance?. The only value you will get is an AC value while the car is running.
Old 08-08-2005, 09:37 PM   #5 (permalink)
View Tried2Live's Photo Gallery
When the engine is running or when the vehicle is moving? Obviously the speed sensor won't give a signal if the engine is turned on, just when the truck is moving.
I think that's what you meant, I just wanted to get some clarification since I'm about to do the same thing.
Tried2Live is offline   Reply With Quote
Old 08-09-2005, 10:33 PM   #6 (permalink)
Luc
Correct, I meant to say when the vehicle is moving, not just idling.
