For starters:
1. It is not neccessary to post twice on two different forums, General and AV Forum.
2. Use the search function
3. See the thread titled
~~~READ B4 POSTING~~~Ultimate audio sticky!! It has almost all the information that you are looking for.
Are you installing this with your factory head unit. You did not specify. If you are, you can splice the remote wire into the ACC wire on the back of you head unit, or you can splice into the power wire for the cigarette lighter/ power outlet. The stock head unit does not have a remote wire connection.
If you are connecting the remote wire to an aftermarket head unit, the wire is usually blue with a white stripe.
