Is a Budget System in my Tacoma Possible?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2005, 01:24 AM   #1 (permalink)
View MikeBuzzsaw's Photo Gallery
I wanted to upgrade my sound system in my 05 tacoma to something better, but affordable. What would the first thing you guys suggest i should be upgrading? I don't want to spend too much, but I want some better sound coming from my speakers.
2005 Toyota Tacoma SR5 TRD Sport Long Bed Indigo
MikeBuzzsaw is offline   Reply With Quote
Old 08-13-2005, 01:45 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
What is your budget?
I would recommend that you upgrade your speakers first.
2007 Camry 2.4L 5M
Old 08-13-2005, 01:55 AM   #3 (permalink)
How Ya Like Me Now?
View Anshu's Photo Gallery
it really depends on your plans.
If you want to go budget now and leave it. yea then speakers and mabye a HU.
If you are looking to go long term upgrades do one part and do it well. Like get a nice headunit and then nice fronts with an amp.
98 V6 XLE
Dell 5100|SB Extigy|PPI DCX 730|NEXT 4.00|Monitor 2.70|ED Nine.1|LPG 26||Alpine Type R|ED 11ov2's and some other junk
Anshu is offline   Reply With Quote
Old 08-13-2005, 02:54 AM   #4 (permalink)
500 at most.
Probably long term, but something simple. Maybe an amp and a sub.
Old 08-13-2005, 03:01 AM   #5 (permalink)
cam2Xrunner's Avatar
Thank You!!!!!
A budget system to me is 1500 dollars. A budget to another person can be 150 dollars.
Mike, how much money do you want to spend? Also do you plan on installing this yourself? Do you have access to a Scrollsaw or a JigSaw, or would you prefer to buy precut MDF baffles for your front speakers?
This is what you're working with.
Access Cab depth.
Double Cab depth
As you can see you will need to use a speaker adapter to fit any kind of speaker. I recomend 6.5" to 7" Mids. 6x9's are no good.
You'll need to make an adapter like this one.
If you don't want to make one you have two choices. Marv will sell you adapters identical to those one(he made them) or you can get plastic ones on ebay, but you are stuck with what size speaker opening they made.
I recomend going through Marv if you want to have some made. He can make the Adapter to fit the diameter needed for whatever mid you chose.
http://community-2.webtv.net/MarvsPlace/MarvsPlace/
I'd say the best upgrade you can do for the money is a decent set of component speakers and an amp for them. You don't have to change your headunit to have a great sounding system. The install I did in the truck pictured above is one of the best I've heard and it uses the factory headunit via the NE-774V from www.davidnavone.com
I would suggest an amp that will do at least 75 watts rms x 4. This way you can either bridge the amp to the front components, or run them off the front channels, then bridge the rear channels to power a single sub.
But we do need to know what you consider a budget before we can make recomendations.
Old 08-13-2005, 03:02 AM   #6 (permalink)
Originally Posted by MikeBuzzsaw
500 at most.
Cool
So you don't want to replace your front speakers?
Old 08-13-2005, 12:32 PM   #7 (permalink)
Simple.
View Schmiess's Photo Gallery
For my 98 xtra cab tacoma I'm putting in new components, 2 Diamond amps, and 2 6.5" subs and everything total cost me $650. And the comps I used are perfect for a shallow mounting depth (1.85 inches) Exile Car Audio. And be sure to keep checking ebay for amps/HUs these guys recommend. I got some nice deals there.
-Mike
Schmiess is offline   Reply With Quote
