Originally Posted by 93' camry
Could i hook the light in the trunk up to my amp and have my + go to my battery cable and the - to my ground?
If you hook it up like said, the light will be on all the time unless you wire a switch inline.
If that doesnt work can i use the oem trunk light wires?
Yes, but the light will only be on whenever the trunk is open.
One last Q, i have my power lead from my amp running into my cig lighter
The power lead (+12V constant) from the amp is suppose to go straight to the battery. And you want it fused no further then 18" away from the battery.
