Installing aftermarket in 99 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2005, 02:01 PM   #1 (permalink)
View Crotchy's Photo Gallery
Canada Installing aftermarket in 99 Corolla
Hey guys.
A co-worker of mine asked me to install an aftermarket deck in a 99 Corolla CE.
Is there anything special that I need to know about the wiring harness? What model should I get? Antenna adapter? Is there any limitations as to what can be installed (1 Din, 1.5, 2 din?)
Also, how hard is it to remove factory deck and do the swap. Please let me know
If you have any links, please post thanks
Cheers
Crotchy is offline   Reply With Quote
Old 08-22-2005, 02:13 PM   #2 (permalink)
cam2Xrunner's Avatar
Welcome to TN
Check out this PDF link.
http://www.installdr.com/InstallDocs...PDF/869001.pdf
You'll need this installation harness.
http://www.cardomain.com/item/SCOTA02B?vq_id=none
Old 09-06-2005, 03:47 AM   #3 (permalink)
Banned
modifierLE's Avatar
View modifierLE's Photo Gallery
Its easy as Pull, screw, push, screw again, and pop in. that is assuming you have a aftermarket harness for that car so its just plug and play.
modifierLE is offline   Reply With Quote
Old 09-11-2005, 01:07 AM   #4 (permalink)
View XKWISIT1's Photo Gallery
You will need a dash kit since there is a slight curve to the dash and a harness in order to prevent you from cutting the vehicle's harness
XKWISIT1 is offline   Reply With Quote
Old 09-12-2005, 02:23 AM   #5 (permalink)
View NisAznMonk's Photo Gallery
You could always use www.sfxaudio.com and click on the Installation Application Wizard link. Its on the right side
Click here for my system:
http://www.toyotanation.com/forum/sh...ad.php?t=59223
AIM = NisAznMonk
NisAznMonk is offline   Reply With Quote
