Well when my friend moved away he gave me his subs which were 2 Infinity 10" 1030W with a sealed enclosure. Its been sitting in my room for awhile and I want of put it in now, but I don't have an amp yet and I was thinking of getting the infinity 310A mono amp since its pretty cheap on ebay and people say it sounds good.
Infinity 10" 1030W Subwoofer
* Size: 10 inch
* Rec. Sealed Box Dims: 0.75 cu.ft.
* Rec. Ported Box Dims: 1.75 cu.ft.
* Free Air Usage: yes
* Sensitivity: 90 dB
* Frequency Response: 25-250 Hz
* Recommended RMS Power: 250W
* Peak Power Handling: 1000W
* Impedance: 4 ohms
Infinity 310A 1-Channel Car Amplifier
* Amplifier Type: Mono
* RMS Power: 116W x 1 @ 4 ohms
* THD at 4-Ohm RMS Power: <1 %
* RMS Power: 312W x 1 @ 2 ohms
* Speaker Level Inputs: No
* Preamp Outputs: Yes
* Built-In Crossovers: LP
* Bass Boost: 0 - 12 dB
* Frequency Response: 17-302 Hz
* Signal to Noise Ratio: 81 dB
* Fuse Rating: 30 amps
Since the subwoofers are SVC (i think), can i hook it up like this wiring diagram? and get 312 rms going to the subs at 2 ohm stable? I know its underpowering the subs, is it too little power or will it work?
Thank You
