Power cable through firewall<----- HELP - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2002, 09:49 PM   #16 (permalink)
TN Ass Man
DrtySthV6SE's Avatar
View DrtySthV6SE's Photo Gallery
my bad dude, i did not mean to get an attitude : . but i do all the shit on the car my self and i dont like drilling random holes in places.
peace
Pioneer Premier, Elemental Designs, SoundSplinter, Resonant Engineering Audio, Stinger, Optima, Rockford Fosgate
DrtySthV6SE is offline   Reply With Quote
Old 10-16-2002, 09:53 PM   #17 (permalink)
View jeff39's Photo Gallery
i got this from ray ray
find the grommet hole by your left strut tower in the engine bay. when you run the cable thru there it ends up in the front left wheel fender well. to operate in this area it may be easier to remove the wheel altogether. remove the splash guard. you'll see the rubber boot that you can poke a hole thru to access the interior cabin. it'll pop out by your dead pedal underneath the dash. from there you can run the power cable to wherever you want.
make sure you protect your cable properly to avoid fraying. use wire loom in exposed areas and grommets where the wire goes thru any sharp edged holes.
it sounds easy and a good. i still havent done it but this is the way i am going to do it.
jeff39 is offline   Reply With Quote
Old 10-17-2002, 08:47 PM   #18 (permalink)
View wontonjohnny's Photo Gallery
thanks for the tip... but i found away from the battery into the fender/wheelwell and from there went into the hole by the door hing on the driver side. the hole was plenty big enough to fit the 4 awg power cable.
i just poked a hole through the rubber making sure not to damage any wires and thats it. it a pretty nice find, leads right to the side kick panel and under the carpet.
5 speed 3vzfe - RIP
project F23 CL-T
Custom Y-pipe Project
Custom 1-Piece CAI Project
wontonjohnny is offline   Reply With Quote
Old 10-17-2002, 08:51 PM   #19 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308675
Cool. I'm glad it all worked out.
It wasn't as hard as it sounded at first, was it? :wink:
-Charlie
