What do these adjustments mean/do? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2005, 12:44 AM   #1 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
not too familiar with the following:
subsonic: 15-35Hz
low pass: 35-250Hz - this blocks out certain high freq right?
phase: 0-180 degrees
bass eq: 0-18dB - this is just the bass volume right?
please enlighten me as detailed as possible as how to go about adusting them, thank you.
WhiteRabbit is offline   Reply With Quote
Old 09-11-2005, 10:36 AM   #2 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
subsonic: 15-35Hz
subsonic is mostly used on ported boxes. It keeps the sub from going below certain frequncies.. so it doesnt hurt it.
low pass tell the sub what frequencies it should play up to.
phase is something with the angle of it.. i forgot awhile ago.
bass eq is a bass boost
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 09-11-2005, 07:23 PM   #3 (permalink)
TN's furry friend
anyone else on subsonic and phase?
Old 09-11-2005, 07:40 PM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $510425
Subsonic filters out whatever is below that setting. So basically your sub will output the frequencies above the subsonic filter freq and below the LPF freq.
Phase is the angle of the output. If 0 degree, it will output as the wave form is input. If 180 degrees, the wave form will be off by 180 degrees or 1/2 wave length compare to the rest of the system. Bass frequencies can cancel out if they are output in a certain way. It's almost like a time delay function, but not quite..it varies depending on the frequency. I dunno really how to explain it.
2007 Camry 2.4L 5M
Old 09-11-2005, 08:04 PM   #5 (permalink)
TN's furry friend
^any tips on adjusting?
