90 Camry Security System Disable - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2005, 09:32 PM   #1 (permalink)
View Mike C.'s Photo Gallery
I own a 1990 Toyota Camry which is equipped with a Fujitsu Ten (Toyota)
Vehicle Security System. I recently lost the only keyless remote that
came with the car and have had no luck finding a replacement. The alarm now
goes off when the door is opened and won't let the car start (had to disconnect the battery). Even if a replacement remote were available it would probably cost more
than the alarm system is worth to me. As such, I decided to simply remove the security system but it is sophisticated enough to disable the starting circuit when the ECU is
unplugged. I have tried to obtain service information on the system
from Toyota to no avail. They show the ECU part number in their system
but that's it. I have the factory electrical manual for the car and
unfortunately there are no wiring diagrams showing how the security
system is wired into the car. Although the system appears to be factory
installed (the wiring loom does not look aftermarket), the car's
original owner thought it was dealer installed. Can anyone
help me locate information on this system, ideally in the form of a
schematic showing what the 18 different wires connect to on the car?
With this information, I'm sure I could restore the car to running order
less the security system. I have even tried contacting Fujitsu Ten's car
electronics division with no response.
A description of the ECU is as follows: Toyota part number
00398-00910, serial no. 900219M256
Also printed on the ECU, FCC ID: BABMW-8170 MW-8170 Fujitsu Ten
Limited made in Japan
Mike C. is offline   Reply With Quote
Old 09-15-2005, 01:00 AM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
wow....never heard of a gen2 with factory keyless entry, i seriously doubt its factory.
good luck man.
worse comes to worse, have it towed to a installer and see if they'll cut it out for you.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 09-15-2005, 08:57 PM   #3 (permalink)
It is strange. The ECU has an official Toyota part number, the wiring loom looks very integrated into the under dash loom. Yet Toyota has no information available on it. It looks too good to be dealer installed...
Old 09-15-2005, 09:54 PM   #4 (permalink)
cam2Xrunner's Avatar
This is a ? for 88 LE
Sorry I can't help, I know nothing about alarms.
Old 09-17-2005, 08:18 PM   #5 (permalink)
Luc
View Luc's Photo Gallery
Though I don't know how "similar" it is to a Previa alarm, but if it's anything like it, once you take the alarm out, you have to find the starter kill relay and reconnect the 12-gauge starter wires together in order for the car to turn over. Unfortunately, there are no markings on the alarm case to show what the identification of the wires are. These "true" OEM are all plug-and-play, so there is no splicing involved like aftermarket alarms.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 10-20-2008, 11:45 AM   #6 (permalink)
View deadlyquasar's Photo Gallery
I've got the same problem with a 93 celica. same fujitsu ten and I can't get to work now because my own car thinks I'm stealing it.
deadlyquasar is offline   Reply With Quote
