find the grommet hole by your left strut tower in the engine bay. when you run the cable thru there it ends up in the front left wheel fender well. to operate in this area it may be easier to remove the wheel altogether. remove the splash guard. you'll see the rubber boot that you can poke a hole thru to access the interior cabin. it'll pop out by your dead pedal underneath the dash. from there you can run the power cable to wherever you want.
make sure you protect your cable properly to avoid fraying. use wire loom in exposed areas and grommets where the wire goes thru any sharp edged holes.
*i knew i should've taken pics when i did mine!*
-rayray
