This kind of confuses me.
My problem is the factory head unit has 4 "speaker wires" (Red:R+, White:R-, Black:L+, Green:L-) for amplifier input with a Black shielded ground.
Personally what I would do if you don't have a prewired harness to bypass the amp, is to just hardwire the Eclipse. Find out what the neccesary wires are to power on and turn on the headunit, then run speaker wire from the headunit to the speaker wiring that comes out of the amp. Doing this you will basically be bypassing the amp, but the hard way
But if you want to make life alot easier-Just wait til you have aftermarket external amplifiers so you can hook them up using RCA's. Or just use the headunit's power and replace the speakers at the same time, and just run new speaker wire from the headunit to the speakers.
Although, I can understand your wanting to get the headunit in right away
