Originally Posted by bobcrane
I've finally gotten around to pulling the dash apart again and here's what I've found:
1. There is one additional harness (grouped with the harness that plugs into the OEM stereo) that does not plug into anything. It's 12 pins (7 on top, 5 on bottom). I've hit it with the meter and found nothing, no ground, no power, nothing.
That might be the speaker wire harness that will allow you to bypass the amp
Hopefully that is the case. Not sure though
2. The wire from all of this (both harness') as well as the wiring to the amp all go up behind the center vents into a plastic case. I'm assuming if I can open that case I might find something more "friendly" to the Scosche plug setup (it seems to be in the same place as Cam2XRunner's picture on another thread).
The problem: How on earth do I get that box open? It looks like I'd have to pull the vent duct but I don't see how without completely dismantling the dash.
The other option may be to pull the glove box again and disconnect the wires going into the amp and run all my wiring from there.
Any ideas???
Try this: If you don't have a harness to get a 12V, ACC Turn on, and ground, then hardwire those yourself. You'll need to get an inline fuse in the new power wire you make and have that fuse close to the battery.
Then try that additional harness and see if that connects to the speaker wire by hooking it up as per the instructions on the bypass thread.
I'm not too sure man, good luck.
